October 18, 2024, 00:21 |
install wave2foam infoam-extend 4.0 error
haozhibin
Rep Power: 2 |
When I install wave2foam in foam-extend-4.0, there are the following errors, please teachers, how can I solve ? Thank you teachers for answering.
/usr/bin/ld: 找不到 -lwaves2Foam collect2: error: ld returned 1 exit status /home/hzb/foam/foam-extend-4.0/wmake/Makefile:159: recipe for target '/home/hzb/foam/hzb-4.0/applications/bin/linux64GccDPOpt/setWaveField' failed make[1]: *** [/home/hzb/foam/hzb-4.0/applications/bin/linux64GccDPOpt/setWaveField] Error 1 /home/hzb/foam/foam-extend-4.0/wmake/MakefileApps:39: recipe for target 'setWaveField' failed make: *** [setWaveField] Error 2 make: 由于错误目标“application”并未重新制作。 ===================================== COMPILE BREEDER ===================================== Nothing available for compilation in the breeder directory. ===================================== COMPILATION DONE ===================================== |
foam extend 4.0, wave2foam |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 14:46 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 07:35 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 05:53 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
