Error foam fatal io error
Old   October 13, 2024, 00:36
Default Error foam fatal io error
Jean Kenyon Verde Castro
Jkenyon99 is on a distinguished road
I am a new OPENFOAM user, I am currently using OPENFOAM for Windows 20.09 and I get this error when running blockMesh.
$ blockMesh
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  dev
     \\/     M anipulation  |
   OpenFOAM for Windows 20.09 (v1)
   Built by CFD Support, www.cfdsupport.com (based on Symscape).
Build  : dev-d26757ee1926
Exec   : C:\OpenFOAM\20.09\cygwin64\opt\OpenFOAM\OpenFOAM-dev\platforms\cygwin64mingw-w64DPInt32Opt\bin\blockMesh.exe
Date   : Oct 13 2024
Time   : 04:12:43
Host   : "LAPTOP-AFBN49KJ"
PID    : 11924
I/O    : uncollated
Case   : C:/OpenFOAM/20.09/Jean Verde Castro-dev/run/Test_Case6
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from
    "system/blockMeshDict"
Using #calcEntry at line 28 in file "C:/OpenFOAM/20.09/Jean Verde Castro-dev/run/Test_Case6/system/blockMeshDict"
Using #codeStream with "C:/OpenFOAM/20.09/Jean Verde Castro-dev/run/Test_Case6/dynamicCode/platforms/cygwin64mingw-w64DPInt32Opt/lib/libcodeStream_dbb3ca960c163a0b114e8c0745bdebff1d5a4023.so"
Invoking "%OPENFOAM_INSTALL_PATH%\..\..\..\bin\bash.exe --login -c \"source /opt/OpenFOAM/OpenFOAM-dev/etc/bashrc.win; wmake -s libso C:/OpenFOAM/20.09/Jean Verde Castro-dev/run/Test_Case6/dynamicCode/_dbb3ca960c163a0b114e8c0745bdebff1d5a4023\""
wmake error: could not change to directory 'C:/OpenFOAM/20.09/Jean'
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_dbb3ca960c163a0b114e8c0745bdebff1d5a4023/platforms/cygwin64mingw-w64DPInt32Opt/lib/libcodeStream_dbb3ca960c163a0b114e8c0745bdebff1d5a4023.so"
file: C:/OpenFOAM/20.09/Jean Verde Castro-dev/run/Test_Case6/system/blockMeshDict from line 17 to line 25.
    From function static void (* Foam::functionEntries::codeStream::getFunction(const Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
    in file db/dictionary/functionEntries/codeStream/codeStream.C at line 211.
FOAM exiting
I would like to know if you know of any solution. I saw in another post that it can be solved by reinstalling make, but how do I do that in Windows?
Thanks in advance for your reply
Kenyon
Jkenyon99 is offline   Reply With Quote
openfoam for windows, wmake error
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 14:46
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
