'readFromStream' function operator?
Old   October 2, 2024, 03:57
Default 'readFromStream' function operator?
Jeongseok Kang
jskang is on a distinguished road
Hello, i'm jskang
I am currently studying OpenFOAM code and reviewing icoFoam.c step by step. However, I have encountered a part that I cannot understand, so I am posting this question in the community. I am studying using ESI version v2312, and I am looking at the following code in IOField.C. The part I do not understand is is >> *this. I assume it means transferring the data from the Istream instance (is) to the IOField instance. Also, I expect that the >> is an operator overloaded for IOField. When I look for this operator definition, I see that >> is defined in Istream, but with different arguments, so it doesn’t seem to be the correct one. Could you tell me where the >> operator for this case is defined?
// * * * * * * * * * * * * * Private Member Functions * * * * * * * * * * * //
template<class Type>
void Foam::IOField<Type>::readFromStream(const bool readOnProc)
Istream& is = readStream(typeName, readOnProc);
if (readOnProc)
is >> *this;
close();
jskang is offline   Reply With Quote
code study
[snappyHexMesh] Invalid Normals for source face to target face while making AMI? Sorabh OpenFOAM Meshing & Mesh Conversion 1 August 3, 2021 07:35
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
