Initial negative temperature compressibleMultiphaseVOF OF11
Old   September 30, 2024, 14:25
Default Initial negative temperature compressibleMultiphaseVOF OF11
Polska
Korneliusz Sierpowski is on a distinguished road
I am working on a problem of a vertical separator that will separate hydrogen from electrolite.
Unfortunately I have error: initial negative temperature.
I tried to change tolerances, mesh, BCs and a lot more.
I am not sure if the BCs are correct. I could not find similar tutorial, so I am asking for help...
I would appreciate any help!
Regards,
Korneliusz
Korneliusz Sierpowski is offline   Reply With Quote
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
