Pedaling Cyclist
Old   September 4, 2024, 06:57
Post Pedaling Cyclist
Clément Pélissier
clempel is on a distinguished road
Dear all,
I developped a Python Dynamic Mesh Code to automatise OpenFOAM simulations in order to simulate a pedaling cyclist using, in particularly, mapFields function.
The simulation I am talking about is computed using a coarse mesh with a level (4 4) for the cyclist patches. The turbulence model is k-omega SST SAS. SAS because I used a dynamicMeshDict to ensure continuity between all the images of the pedaling cycle. An image is calculated over 0.0025s, where dynamicMeshDict is used with kinematic data (6DoF data), and the link between all images is made by mapFields.
However, when I look at my results, the drag coefficient decreases infinitely over time as if the inlet velocity changes over the time but it is not the case. It seems like the energy conservation is not respected but it is impossible. So where does the energy can go ? Do you have some ideas ? Perhaps some of you have had similar experiences in unsteady simulation?
What's more, the residuals look normal, and there's no divergence of velocity or pressure in the logs.
Thank you for your help and your time,
Sincerely,
Clément
clempel is offline   Reply With Quote
dynamicmesh, k-omega sst sas, mapfields, pedaling cyclist
Under Predicting Drag on Cyclist (Fluent) Jacob Flanagan FLUENT 11 September 13, 2019 10:58
Wind tunnel model of an animated cyclist Tigre Main CFD Forum 22 October 29, 2018 01:20
how to model a cyclist klaas FLUENT 1 March 26, 2007 11:20
