error on request for viscosityModel
Old   September 4, 2024, 05:58
Default error on request for viscosityModel
MudaMuda is on a distinguished road
Hi, foamers,
Would be really grateful if someone could help me with this.
Basically, I'm creating a model for wind-driven-rain studies. I'm using latest openFoam.org v12 with solver multiphaseEuler and PIMPLE.
The model I created based on tutorial named aachenBomb and hotBoxs, since I suppose they are both using cloud and particle stuffs.
However, I encountered error "request for viscosityModel physicalProperties from objectRegistry region0 failed available objects of type viscosityModel are 0()"
I have ensured both air and water have their defined in their respective files physicalProperties.air and physicalProperties.water. I check 0 files and schemes and solvers. Just the error persist.
anyone has any suggestion or tips for this one. Please hit me a little bit.
I attached log.foamRun file here. Struggled for weeks, really need a hand here.
Create time
Create mesh for time = 0
Selecting solver multiphaseEuler
Selecting phaseSystem basicMultiphaseSystem
No MRF models present
Selecting phaseModel for air: purePhaseModel
Selecting diameterModel for phase air: isothermal
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
Calculating face flux field phi.air
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
RAS
    model           kOmegaSST;
    turbulence      on;
    printCoeffs     on;
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
Selecting thermophysical transport type RAS
Selecting default RAS thermophysical transport model unityLewisEddyDiffusivity
Selecting phaseModel for water: purePhaseModel
Selecting diameterModel for phase water: constant
    type            heRhoThermo;
    transport       const;
    thermo          eConst;
    equationOfState rhoConst;
    specie          specie;
Calculating face flux field phi.water
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Selecting thermophysical transport type laminar
Selecting default laminar thermophysical transport model unityLewisFourier
Selecting interfaceSurfaceTensionModel for air_water: constant
Selecting dragModel blending method for air_water: linear
Selecting dragModel for air_dispersedIn_water: SchillerNaumann
Selecting dragModel for water_dispersedIn_air: SchillerNaumann
Selecting dragModel for air_segregatedWith_water: segregated
Selecting virtualMassModel blending method for air_water: linear
Selecting virtualMassModel for air_dispersedIn_water: constantCoefficient
Selecting virtualMassModel for water_dispersedIn_air: none
Selecting heatTransferModel blending method for air_water: linear
Selecting heatTransferModel for air_dispersedIn_water: RanzMarshall
Selecting heatTransferModel for water_dispersedIn_air: RanzMarshall
Courant Number mean: 0.0994444 max: 0.1
Creating fvModels from "constant/fvModels"
Selecting finite volume model type clouds
[6]
[6]
[6] --> FOAM FATAL ERROR:
[6]
0()
[6]
[6]     From function [8]
[8]
[8] --> FOAM FATAL ERROR:
[8]
0()
[8]
[8]     From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::viscosityModel]
[8]     in file /home/ubuntu/OpenFOAM/OpenFOAM-12/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 211.
[8]
FOAM parallel run aborting
MudaMuda is offline   Reply With Quote
Old   September 7, 2024, 05:29
I found when OF reading fvModel file, it is request for viscosityModel physicalProperties from objectRegistry region0 failed.
So how can I define the proper physicalProperties? Any function or entry can be used in fvModel file?
viscositymodel, wdr
[OpenFOAM] could not open file .vtk in paraview ali_atrian ParaView 8 August 27, 2014 11:31
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 16:46
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 05:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
[OpenFOAM] Xwindows crash with paraview save srinath ParaView 1 October 15, 2008 10:37
