Error for using overset for a Darrieus turbine with four independent oversets
Old   September 4, 2024, 02:51
Default Error for using overset for a Darrieus turbine with four independent oversets
AJC
Pierre Lecanu
AJC is on a distinguished road
I try to use overset with openfoam for a turbine type Darrieus.I transformed the case of K S S Satya Sasank "aerofoilC" which has a single overset with the 3 blades included. I created 4 overset with 1 blade per overset. in the log of overPimpleDyMFoam, I get this message.
--> FOAM Warning :
From Foam::tmp<Foam:imensionedField<double, Foam::volMesh> > Foam::RASModels::kOmegaSSTLM<BasicTurbulenceModel> ::ReThetat0(const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Internal&, const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Internal&, const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Internal&) const [with BasicTurbulenceModel = Foam::IncompressibleTurbulenceModel<Foam::transpor tModel>; Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Internal = Foam:imensionedField<double, Foam::volMesh>]
in file ../turbulenceModels/lnInclude/kOmegaSSTLM.C at line 305
Number of lambda iterations exceeds maxLambdaIter(10)
can you solve my error? thank you
the software used to create the NACA profile is openscad. If you don't have openscad installed on your computer, here are the stl naca profiles you need to incorporate into the triSurface directories, and delete the ./render.sh command from the Allrun.pre file in each directory.
Last edited by AJC; September 5, 2024 at 02:30. Reason: software used to create NACA profile
AJC is offline   Reply With Quote
darrieus, overset, vawt
Overset meshing with rotational periodic BC for a wind turbine blade Islam Abdelghafar STAR-CCM+ 9 February 23, 2022 12:25
2DOF Planning hull resistance study with overset CFD_fan OpenFOAM Running, Solving & CFD 7 July 13, 2021 06:03
[ANSYS Meshing] 3D rotating wind turbine using overset mesh Paku ANSYS Meshing & Geometry 0 September 11, 2019 00:18
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 15:07
