Could you tell me about the gradU needed when determining the frictional drag?
Old   August 22, 2024, 07:00
Default Could you tell me about the gradU needed when determining the frictional drag?
fish man is on a distinguished road
Line 242 of force.cpp is used to calculate the frictional drag using the laminar flow model in OpenFOAM.
line 242 of force.cpp
-rho()*laminarT.nu*dev(twoSymm(fvc::grad(U)))
The fvc::grad(U) included in this expression is
postProcess -func “grad(U)”
is the same as the one calculated by postProcess -func “grad(U)”?
Thank you in advance.
fish man is offline   Reply With Quote
Old   August 23, 2024, 09:13
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Should be yes. The postProcess uses a pre-defined file. Hence we execute the grad function object which indeed does the following (gradTemplate.C):
template<class Type>
bool Foam::functionObjects::grad::calcGrad()
    typedef GeometricField<Type, fvPatchField, volMesh> VolFieldType;
    typedef GeometricField<Type, fvsPatchField, surfaceMesh> SurfaceFieldType;
    if (foundObject<VolFieldType>(fieldName_, false))
        return store
            resultName_,
            fvc::grad(lookupObject<VolFieldType>(fieldName_)),
            mesh_.changing() && mesh_.cache(resultName_)
    else if (foundObject<SurfaceFieldType>(fieldName_, false))
        return store
            resultName_,
            fvc::grad(lookupObject<SurfaceFieldType>(fieldName_)),
    return false;
As you can see it is fvc::grad(whatEverField).
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   August 25, 2024, 19:56
Smile
Hello
Thank you very much.
I now have a better understanding of "grad".
Old   August 27, 2024, 05:34
Lightbulb
grad(U) derived by postProcess -func “grad(U)” and fvc::grad(U) in the source code had an average error of about 2.9 times when comparing values
It would be great if you could tell me why this is....
Old   August 27, 2024, 07:20
Tobi's Avatar
Tobias Holzmann
How you compare the data? How are you checking the grad from source code (what ever you mean here).
Make sure you have the same discretization schemes active
Keep foaming,
Tobias Holzmann
Old   August 27, 2024, 21:36
Lightbulb
We modified force.c and force.h in
HTML Code:
src/functionObjects/forces/forces
to visualize gradU during analysis.
Then, after the analysis was finished, gradU was derived with
The above two gradUs were compared.
gradu, openfoam
SMALL, GREAT and ROOTVSMALL - what is that? Dommy OpenFOAM Running, Solving & CFD 7 February 20, 2020 10:12
Why is there a great difference between numeca and cfx???? sukiska Fidelity CFD 0 October 12, 2011 11:21
Help needed with Cornell's Gambit airfoil tutorial AW FLUENT 6 February 26, 2010 23:42
Installing Open Foam and needed packages on shared disk for cluster environment k3di OpenFOAM Installation 1 July 8, 2009 08:06
Help needed with laminar couette flow boundary conditions bengt OpenFOAM Running, Solving & CFD 0 March 19, 2009 09:25
