Using fixedProfile to apply a sinusoidal temperature profile |
August 20, 2024, 16:37 |
Nils Tilton
Rep Power: 2 |
Dear OpenFoam Community,
As part of learning OpenFoam, I am solving a simple steady heat conduction problem using laplacianFoam, and I am systematically experimenting with different methods of applying nonuniform Dirichlet boundary conditions. From the OpenFoam documentation and online sources, I have grasped how to apply a polynomial temperature profile using "fixedProfile" and "polynomial." For example, along a patch named west, I can apply the temperature T =1 + 2y using the following entry in my 0/T file: west { type fixedProfile; profile polynomial ( (1 0) (2 1) ); direction (0 1 0); origin 0; } My question is the following. Can I use a similar approach to apply the condition T = cos(y) along the same west boundary? The online documentation for fixedProfile mentions that I can apply a <Function1<Type>> for profile. Meanwhile, I see in the source code files (src/OpenFOAM/primitives/functions/Function1/) that there is a cosine. However, the .H file for cosine seems to imply it's reserved for taking the cosine of time, and not a spatial coordinate. So in summary, is there a way to use "fixedProfile" and "cosine" to apply the condition, or am I barking up the wrong tree? I plan to explore using codeStream next, but didn't like this conceptual issue left hanging. |
August 21, 2024, 03:13 |
Hi Nils,
If you are on the openfoam.com version, you may want to look into some examples of expressions. Best regards, Tom Last edited by tomf; August 21, 2024 at 03:14. Reason: link instead of code |
August 21, 2024, 10:23 |
Nils Tilton
Rep Power: 2 |
Hi Tom,
Thanks for the link. It has some great info I was missing. Best Wishes, Nils |
August 23, 2024, 11:56 |
Nils Tilton
Rep Power: 2 |
Hi All,
For those interested in applying general Dirichlet conditions, here are three ways of applying the sinusoidal temperature profile T=273+80*cos(4*pi*x/Lx) on a boundary patch called north. The first uses OpenFOAM's fixedProfile. The second uses fixedValue with codeStream. The third uses codedFixedProfile Option 1 using fixedProfile with coded: north { type fixedProfile; profile coded name CosineT; codeInclude #{ #include "mathematicalConstants.H" #}; code #{ scalar Lx = 1; scalar pi = 3.141592653589793; return scalar ( 273 + 80*cos(4.0*pi*x/Lx) ); #}; direction (1 0 0); origin 0; } Option 2 using fixedValue with codeStream: north { type fixedValue; value #codeStream { // optional include files codeInclude #{ #include "fvCFD.H" #}; // optional compile options codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; // optional libraries codeLibs #{ -lfiniteVolume \ -lmeshTools #}; code #{ //----------- required to access patch data ------------// const IOdictionary& d = static_cast<const IOdictionary&> ( dict.parent().parent() ); const fvMesh& mesh = refCast<const fvMesh>(d.db()); const label id = mesh.boundary().findPatchID("north"); const fvPatch& patch = mesh.boundary()[id]; //------------------------------------------------------// scalar pi = 3.141592653589793; scalar Lx = 1; scalarField TN(patch.size(), 0.0); forAll(TN, i) { const scalar x = patch.Cf()[i][0]; TN[i] = 273 + 80*cos(4.0*pi*x/Lx); } TN.writeEntry("", os); #}; }; } Option 3 using codedFixedProfile: north { type codedFixedValue; value uniform 0; // optional name CosineCondition; // optional include files codeInclude #{ #include "fvCFD.H" #}; // optional compile options codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; // optional libraries codeLibs #{ -lfiniteVolume \ -lmeshTools #}; code #{ scalar Lx = 1.0; scalar pi = 3.141592653589793; vector xdir(1,0,0); scalarField x( patch().Cf()&xdir ); operator==( 273 + 80*Foam::cos( 4.0*pi*x/Lx ) ); #}; } |
boundary condition., cosine, fixedprofile, openfoam 12 |
Temperature profile with isothermal steady state simulation | Procyon | CFX | 6 | November 11, 2019 12:06 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Please Help! Temperature profile UDF for 3D geometry | subhankar_bhandari | FLUENT | 2 | April 16, 2011 05:30 |
Please Help! Temperature profile UDF for 3D geometry | subhankar_bhandari | FLUENT | 0 | August 16, 2010 08:40 |
Help please! UDF for Temperature profile in 3D | subhankar_bhandari | Fluent UDF and Scheme Programming | 2 | August 16, 2010 08:37 |
