Interfoam - apply limitFields only to air fraction |
August 8, 2024, 06:23 |
Rep Power: 5 |
Hi!
I am running a simulation in OpenFOAM using the interFoam solver. During my simulation, the velocities in the air fraction become unrealistically high. Since these effects are tampering my time step, I'd like to limit the velocities in the air fraction artificially by using the limitFields function in my controlDict. The only thing is, that when I set a limit for the velocity field, both the velocity of my air and water fraction is limited. I use the following: Code:
limitVelocity { type limitFields; libs ("libfieldFunctionObjects.so"); fields (U); writeControl adjustableRunTime; writeInterval 10; limit both; min 0; // Set the minimum value for the velocity magnitude max 1; // Set the maximum value for the velocity magnitude (adjust as needed) } If another function than limitFields is more suitable, please let me know as well. Best, Bas |
August 9, 2024, 09:05 |
Solved
Rep Power: 5 |
A thourough search brought me here:
https://github.com/nicolasbadano/air...on/tree/master I only could get it running for openFoam version 1812. |
October 30, 2024, 10:23 |
Michael Sukham
Rep Power: 6 |
It does work with openfoam 12 as well in fvModels entry. But I dont see any changes in the velocity
interfoam, limitfields, openfoam, vof |
Limiting volume fraction in interFoam | sita | OpenFOAM Running, Solving & CFD | 7 | June 5, 2024 12:58 |
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 22:36 |
multiphase turbulance case floating error | harsha_kulkarni | OpenFOAM Running, Solving & CFD | 3 | February 18, 2016 06:06 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 02:40 |
