--> FOAM FATAL ERROR: Negative initial temperature T0:
Old   August 4, 2024, 23:58
Default --> FOAM FATAL ERROR: Negative initial temperature T0:
muhammad abdul fattah
fattah2110 is on a distinguished road
Hello I just used openfoam to simulate 2 heat sources with 1 fin and also air ducts with "chtMultiRegionFoam" simulation but there is always a fattal error: negative initial temperature T0: -307.56 as I have attached, please help me to solve this problem, thank you very much.
Solving for fluid region fluid
DILUPBiCGStab: Solving for Ux, Initial residual = 0.861158, Final residual = 7.41943e-08, No Iterations 3
DILUPBiCGStab: Solving for Uy, Initial residual = 0.482332, Final residual = 3.06308e-08, No Iterations 3
DILUPBiCGStab: Solving for Uz, Initial residual = 0.517279, Final residual = 2.47086e-08, No Iterations 3
DILUPBiCGStab: Solving for h, Initial residual = 0.896312, Final residual = 3.01582e-08, No Iterations 7
Min/max T:-307.56 758.467
GAMG: Solving for p_rgh, Initial residual = 0.049043, Final residual = 0.000457518, No Iterations 3
GAMG: Solving for p_rgh, Initial residual = 0.0531826, Final residual = 0.000423879, No Iterations 3
GAMG: Solving for p_rgh, Initial residual = 0.0333591, Final residual = 7.1701e-08, No Iterations 20
time step continuity errors : sum local = 4.28568e+08, global = -1.71526e+07, cumulative = -1.71526e+07
Min/max rho:1.196 1.196
Solving for solid region heater1
GAMG: Solving for h, Initial residual = 0.78903, Final residual = 6.75112e-07, No Iterations 9
Min/max T:370.469 389.851
Solving for solid region heater2
GAMG: Solving for h, Initial residual = 0.858166, Final residual = 4.18087e-07, No Iterations 9
Min/max T:359.635 376.68
Solving for solid region fins
GAMG: Solving for h, Initial residual = 0.899828, Final residual = 9.26947e-07, No Iterations 29
Min/max T:283.149 473.151
ExecutionTime = 440.6 s ClockTime = 442 s
volFieldValue volAvgFinTemperature write:
volAverage() of T = 417.445
volFieldValue volAvgHeater1Temperature write:
volAverage() of T = 381.695
volFieldValue volAvgHeater2Temperature write:
volAverage() of T = 370.382
surfaceFieldValue averageTempHeater1FinInterface write:
areaAverage(heater1_to_fins) of T = 382.572
surfaceFieldValue averageTempHeater2FinInterface write:
areaAverage(heater2_to_fins) of T = 372.231
Region: fluid Courant Number mean: 4.66366e+13 max: 7.89855e+16
Region: heater1 Diffusion Number mean: 2.84429e+09 max: 2.86588e+10
Region: heater2 Diffusion Number mean: 3.06795e+09 max: 3.46375e+10
Region: fins Diffusion Number mean: 6.30975e+07 max: 1.56533e+09
Time = 54
DILUPBiCGStab: Solving for Ux, Initial residual = 0.765781, Final residual = 4.85981e-08, No Iterations 3
DILUPBiCGStab: Solving for Uy, Initial residual = 0.328549, Final residual = 2.75657e-08, No Iterations 3
DILUPBiCGStab: Solving for Uz, Initial residual = 0.312839, Final residual = 6.17003e-08, No Iterations 3
DILUPBiCGStab: Solving for h, Initial residual = 0.825268, Final residual = 2.87913e-08, No Iterations 7
Negative initial temperature T0: -307.56
From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const, bool) const [with Thermo = Foam::hConstThermo<Foam::rhoConst<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::rho Const<Foam::specie> >, Foam::sensibleEnthalpy>]
in file /home/torasia/OpenFOAM/OpenFOAM-7/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 56.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::species::thermo<Foam::hConstThermo<Foam::rho Const<Foam::specie> >, Foam::sensibleEnthalpy>::T(double, double, double, double (Foam::species::thermo<Foam::hConstThermo<Foam::rh oConst<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam::rh oConst<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam::rh oConst<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double) const, bool) const at ??:?
#3 Foam::heRhoThermo<Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::singleComponentMixture<F oam::constTransport<Foam::species::thermo<Foam::hC onstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::calculate() at ??:?
#4 Foam::heRhoThermo<Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::singleComponentMixture<F oam::constTransport<Foam::species::thermo<Foam::hC onstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::correct() at ??:?
#5 ? in "/home/torasia/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt64Opt/bin/chtMultiRegionFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7 ? in "/home/torasia/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt64Opt/bin/chtMultiRegionFoam"
Aborted
fattah2110 is offline   Reply With Quote
Old   September 26, 2024, 11:05
Default Solve this problem
ShaowuMa
Shaowu is on a distinguished road
Hi,I also have this problem. There is an issue with the quality of your mesh. You should check if your mesh complies with the gradient consistency principle. In areas with significant changes in physical quantities, the mesh size should be consistent or the mesh specifications should change in a certain direction. Mesh density oscillations are not allowed.
Shaowu is offline   Reply With Quote
chtmultiregionfoam, fatal error, heattransfer, negative heat transfer, openfoam7
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
