Multi-region mesh for CHT problem
Old   July 30, 2024, 10:46
Default Multi-region mesh for CHT problem
Daniil Kalaev
Danilo_King is on a distinguished road
Greetings to everyone! My first post here.
I'm relatively new to OpenFOAM and I have to use it for my thesis.
I'm running multiple simple topology optimization cases from which I extract the resulting fluid domain (example in the attached image) that I need to use for further testing with a CHT solver. During the meshing the challenge is that within the boundaries of the fluid region I need the rest to be filled with the solid region cells (like making it a full block again).
So far I tried creating a blockMesh of the same size as the boundaries of the fluid region assigning it to solid
  blocks(hex (0 1 2 3 4 5 6 7) solid (100 100 36) simpleGrading (1 1 1));
and then in snappyHexMeshDict set the cellZone for my fluid domain
refinementSurfaces
        solid_to_fluid
            level           ( 0 0 );
            faceZone        solid_to_fluid;
            cellZone        fluid;
            mode            inside;
and another approach where instead of the blockMesh of the same size, I use an extra STL of the same size superimposed with my fluid domain STL.
Both methodologies give me the desired result visually with both regions separated, but I keep getting errors from paraview that the mesh is missing cells and I'm unable to proceed further, which makes me doubt the correctness of my approach so I am asking for help the almighty forum.
I also attached the snappyHexMeshDict and the blockMeshDict.
blockMeshDict.txt
snappyHexMeshDict.txt
Danilo_King is offline   Reply With Quote
cht, mesh 3d, meshing advice, openfoam
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 07:51
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 14:28
[Other] Material properties in multi region foam and refining mesh for each region mukut OpenFOAM Meshing & Mesh Conversion 2 October 7, 2013 03:08
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
