Lorenzo
Rep Power: 0 ![]() |
I'm trying to do a simulation of a propeller, so I need to set the rotation of the domain around the propeller (according to the MFR approach). Following a tutorial on Youtube (https://www.youtube.com/watch?v=79-x2YQVE6Q&t=1690s, 24:29), i have to use setSet command, but i get this message:
Command 'setSet' not found, but can be installed with: sudo apt install openfoam I tried to do this, then to uninstall and reinstall openfoam, but it still can't find this command. How can I solve this? |
#2 | |
Yann
Rep Power: 27 ![]() |
You are most likely using OpenFOAM-10 or 11. setSet has been deprecated and replaced by topoSet: Quote:
Lorenzo
Thank you so much, I will try by using another version.
Yann
You can do the same thing with topoSet, but of course you will have to learn how to use topoSet first.
If you want to stick to this specific tutorial, the hassle-free way would be to use the exact same OpenFOAM version. Generally speaking, there are changes on each version, so it's very likely to bump into things working differently when you try to reproduce a tutorial made with a different version than the one you are using. |
propeller, rotatemesh, setset |
Gmsh installation on terminal help | spitfire | Main CFD Forum | 4 | July 27, 2017 15:11 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 11:37 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 01:36 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
