Trouble setting thermal boundary conditions
Old   June 12, 2024, 06:43
Post Trouble setting thermal boundary conditions
srikanth
alpha_13 is on a distinguished road
Hello ,
I'm simulating flow past a bluff body using modified icoFoam solver with temperature equations.I'm conducting a mesh convergence test to ensure the mesh captures small thermal boundary layers.To achieve this, I'm using a high Prandtl number (e.g., 50) and setting the temperature of the fluid (mean film temperature) and the obstacle surface (isothermal) to be the same.However, I'm unsure about setting up the temperature (T) file within the 0 file. After reviewing online resources, I've identified two potential approaches, which I've outlined below.I apologize if this seems like a basic question. I'm relatively new to OpenFOAM and CFD in general.
Could you please help me choose the appropriate approach for the T file configuration?
option 1)
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 10
\\/ M anipulation |
FoamFile
format ascii;
class volScalarField;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform (100 0 0);
boundaryField
inlet
type fixedValue;
value uniform (100 0 0);
outlet
type fixedValue;
top
type fixedValue;
bottom
type fixedValue;
obstacle
type fixedValue;
front_back
type empty;
option 2)
\\/ M anipulation |
FoamFile
format ascii;
object T;
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
top
type zeroGradient;
bottom
type zeroGradient;
obstacle
type fixedValue;
front_back
type empty;
alpha_13 is offline   Reply With Quote
icofoam, temperature bc
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 06:53
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
