Extend-bazaar/Toolkits/Fluid-structure interaction docker image |
May 27, 2024, 22:50 |
Selimhan Dogan
Hello, I want to use OpenFOAM with an extend-bazaar package. Ideally, if there is a docker, I can plug and play. The last time I tried to install this package, I had a hard time. I am also open to a different fluid-structure interaction package if available.
Edit: Found a repository if anyone needs it: https://github.com/FoamScience/foam-extend-4.1-openmpi |
extend-bazaar, fluid-structure, fluid-structure,wavefoam, openfoam 11 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | ANSYS | 0 | July 22, 2016 13:40 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 13:39 |
About one-way Fluid-Structure Interaction, form structure to fluid !? | xq712000 | ANSYS | 0 | July 15, 2016 09:40 |
Fluid structure interaction. | Haree | FLUENT | 2 | August 7, 2010 02:56 |
Wave structure interaction | R.Balaji | Main CFD Forum | 0 | March 17, 2002 11:56 |
