solver incompressibleDenseParticleFluid: command not found |
May 23, 2024, 05:44 |
I am trying to run the incompressibleDenseParticleFluid tutorials. I started with the column. there is no Allrun command, so I tried to run it by using the solver found in the controlDict file (i.e. incompressibleDenseParticleFluid). But the solver is not found.
I tried from different sources of openFoam. In both cases I checked the solvers in the version through CD $FOAM_SOLVERS and it seems that the solver is not present. openFoam11 solvers directory boundaryFoam chemFoam foamMultiRun foamRun potentialFoam openFoam2306 solvers directory acoustic compressible doc finiteArea lagrangian basic discreteMethods electromagnetics heatTransfer multiphase combustion DNS financial incompressible stressAnalysis blockMesh works, so I think both installations work fine. the solver does exist in the $FOAM_APP/modules directory I tried copying it in the solver directory but couldn't due to security settings. Also not sure if this is the correct way to go about things Also tried calling it through incompressibleDenseParticleFluidFoam incompressibleFluidFoam Any help appreciated Thanks |
September 2, 2024, 21:53 |
Erol Bicer
Try the commands below from your terminal. Code:
blockMesh && foamRun |
particle cloud, solve compliation, solver error, solver linking |
Two phase flow in porous medium | Milaad | OpenFOAM | 7 | July 1, 2024 05:08 |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
