UMean and U
Old   May 11, 2024, 11:07
Default UMean and U
Hakan
demirmvc is on a distinguished road
In the control dictionary file, there are entries for 'U' and 'UMean'. What are the differences between these two terms?
const volVectorField& U = mesh.lookupObject<volVectorField>("U");
U
mean on;
prime2Mean off;
base time;
Could someone explain the differences?
I know 'U' represents the instantaneous velocity field in a CFD simulation.
'UMean' the time-averaged velocity field.
Is UMean used to find the average over the entire duration? In other words, is the UMean used to calculate u'?
demirmvc is offline   Reply With Quote
Old   May 13, 2024, 19:29
Shravan
Severus is on a distinguished road
To see how UMean and UPrime2Mean is calculated, check here: https://www.openfoam.com/documentati...ldAverage.html
Yes, U is instantaneous velocity, UMean is time averaged velocity and UMean is needed to calculate UPrime2Mean. The averaging need not always be for the entire duration (see the Usage section in the above link).
By default you average for the entire duration if you don’t specify anything.
However, you can provide the start time (timeStart) and end time (timeEnd) for averaging, so that you will only perform the averaging within that specified time window and not for the entire duration.
Thanks
Severus is offline   Reply With Quote
openfoam, turbulence, uprime, velocity
LES UPrime2Mean from previously calculated UMean mjavrincon OpenFOAM Running, Solving & CFD 2 September 6, 2024 12:16
Access UMean at particular run time absrocks OpenFOAM Running, Solving & CFD 3 July 7, 2021 21:29
[General] ParaView skips timeframe for UMean Max0139 ParaView 1 November 24, 2016 06:29
convert mean velocity results (UMean) to fluent McCharles OpenFOAM Post-Processing 0 August 18, 2016 06:09
Umean balakrishnan OpenFOAM Running, Solving & CFD 4 March 11, 2005 12:31
