depth at oulet boundary condition.
Old   May 8, 2024, 01:19
Default depth at oulet boundary condition.
Shashank Shekhar Sandilya
sss.nitp is on a distinguished road
hello everyone,
i want to apply depth at outlet as a boundary condition for my open channel flow case. i am using InterFoam solver. please suggest how to modify the existing boundary condition to suit my open channel case.
sss.nitp is offline   Reply With Quote
Old   May 8, 2024, 01:25
Will Kernkamp
wkernkamp is on a distinguished road
Maybe you could force air into the domain at the outlet side. Otherwise you would need to couple your inlet flow to get the right outflow level.
wkernkamp is offline   Reply With Quote
Old   May 8, 2024, 02:18
Thanks for the reply. i will try that. Does it possible to modify the existing boundary condition to more physically describe our case by assigning Depth at outlet as a boundary condition. Depth at outlet of the channel is considered as most import boundary condition for open channel flow.
thanks and regards
Old   May 8, 2024, 17:19
Will Kernkamp
Originally Posted by sss.nitp View Post
Thanks for the reply. i will try that. Does it possible to modify the existing boundary condition to more physically describe our case by assigning Depth at outlet as a boundary condition......
thanks and regards
Not sure that it is possible do define depth as a boundary condition. The boundary is physical. So you will need to define flow conditions at the boundary. Maybe you can define p, including the hydrostatic component, to get the right depth you want.
Old   May 9, 2024, 01:34
Thank you for the reply,
Maybe you can define p, including the hydrostatic component, to get the right depth you want. can you please elaborate that or suggest some reference. i am using interFoam solver for simulating open channel flow.
my boundary condition at outlet are:
at outlet
p_rgh
type fixedFluxPressure;
U
type zeroGradient;
Thanks and Regards
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 03:53
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
