First time User fvOptions error OpenFOAM 11
Old   May 1, 2024, 12:22
Exclamation First time User fvOptions error OpenFOAM 11
Terence
tfisherira is on a distinguished road
--> FOAM FATAL IO ERROR:
keyword type is undefined in dictionary "/home/OpenFOAM/run/heatedDuct/constant/heater/fvOptions/options"
file: /home/OpenFOAM/run/heatedDuct/constant/heater/fvOptions/options from line 22 to line 33.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 827.
FOAM exiting
This is the error I receive when trying to run a program from a 3 yr old Heat Transfer tutorial https://youtu.be/Nhhm-ZPxVRc?si=9P15Zi3DpA9oKFSm
Here is my fvOptions file
 FoamFile
     version     2.0;
     format      ascii;
     class       dictionary;
     location    "constant/heater";
     object      fvOptions;
 options
     energySource
         type            scalarSemiImplicitSource;
         selectionMode   all;
         volumeMode      specific;
         injectionRateSuSp
             name h;
             timeStart           0;
             duration            1;
             selectionMode       all;
             explicit            10e7;
             //implicit          ;{}
tfisherira is offline   Reply With Quote
Old   May 2, 2024, 05:38
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
The error says that the options part does not have a type entry. Probably you have a level of {} too many. Try this:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvOptions;
energySource
    selectionMode   all;
    injectionRateSuSp
        name h;
        timeStart           0;
        duration            1;
        selectionMode       all;
        explicit            10e7;
        //implicit          ;{}
It may then throw a different error, as syntax may have changed in three years.
Hope this helps.
Tom
tomf is offline   Reply With Quote
Old   May 2, 2024, 09:25
Terence
Thanks,
That helped to generate a different error. Unfortunately, I am quite inexperienced with openFOAM and have very little idea of what to do next. The number of changes between versions makes it very difficult to learn from scratch.
Here is the new error I receive:
Unknown fvModel scalarSemiImplicitSource
Valid fvModels are:
22
accelerationSource
actuationDiskSource
buoyancyEnergy
buoyancyForce
coded
effectivenessHeatExchangerSource
explicitPorositySource
heatSource
heatTransfer
interRegionExplicitPorositySource
interRegionHeatTransfer
massSource
phaseLimitStabilisation
radialActuationDiskSource
rotorDisk
semiImplicitSource
sixDoFAccelerationSource
solidEquilibriumEnergySource
solidificationMeltingSource
volumeFractionSource
zeroDimensionalFixedPressure
zeroDimensionalMassSource
Old   May 2, 2024, 09:38
Tom Fahner
Indeed some of these changes can be difficult to trace back. However given the name, I guess you should use semiImplicitSource.
The link above will give some more information on the usage as it is implemented in v11. You may need to "translate" your setup to the new syntax.
Good luck,
Tom
fvoptions heat source, openfoam 11, scalarsemiimplicitsource, type
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
How to make user routine just be called once in one time step? doublestrong CFX 3 October 22, 2018 00:06
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
