Mahek SANGHVI
Rep Power: 0 ![]() |
I am working on fluid mixing where i put 2 fluids inside a cylinder and rotate it with a rotor. I need help to rotate the rotor with an angular velocity. And help to how to add properties for 2 particles.
I have some basic idea of changing files in 0 and constant can someone explain in detail and also do i need to make any changes in solver?? |
Rotational Velocity in Workbench | aaganoglu | Main CFD Forum | 0 | April 3, 2018 12:47 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
WSS and normal velocity gradient for the slanted pipe | wanna88 | FLUENT | 2 | October 1, 2012 22:34 |
udf for changing rotational velocity | peterchen | Fluent UDF and Scheme Programming | 4 | October 19, 2010 06:43 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
