Supersonic Inlet Shock causing issues in diffuser
Old   April 15, 2024, 14:37
Default Supersonic Inlet Shock causing issues in diffuser
chc
chc is on a distinguished road
I’m currently trying to run a simulation examining unsteady flow as a result of shock waves using rhoCentralFoam. My case deals with an inlet in which I’m trying to choke the flow to examine the effects of non-critical flow conditions. During preliminary tests, my diffuser has no obstacle and is open, and the simulation runs as expected. However, when trying to implement a type of plug, I’m getting shockwaves that propagate out past the cowl and are creating high densities and very low speeds. Compared to similar studies, this shouldn’t be happening as the mass flow restriction has been minimal so far, and I believe it’s geometrical, and possibly related to the wall BC I have in the diffuser outlet. I understand that I could directly limit the mass flow through that patch, but I am trying to make it as similar as possible to related studies. Any help to figure this issue out is appreciated.
Inlet with no mass flow plug: https://github.com/CChe36/22blockpar
Inlet with adjustable mass flow plug: https://github.com/CChe36/i_22blockpar
chc is offline   Reply With Quote
blockmeshdict, boundary conditions, mass flow rate, rhocentralfoam, supersonic inlet
[OLAFLOW] The OLAFLOW Thread Phicau OpenFOAM Community Contributions 459 September 12, 2024 12:47
Supersonic Inlet Simulation Boitshoko Baloyi STAR-CCM+ 6 July 8, 2023 13:30
What is causing strange low-velocity border at inlet? jhz FLUENT 0 February 24, 2021 14:23
External-Compression Supersonic Inlet CFD Boitshoko Baloyi STAR-CCM+ 3 July 1, 2019 08:13
Inlet diffuser of ramjet Mohammad Kermani Main CFD Forum 25 December 29, 2000 19:46
