Limit values of a variable
Old   March 13, 2024, 12:52
Default Limit values of a variable
Giorgio
giorgianig is on a distinguished road
I am using mapField to map a coverged solution from a coarse mesh to a fine one. When I re-start the simulation on the fine mesh, the simulation crashes at the beginning of the time loop.
I have discovered that there are a bunch of points (like 5 points) where omega (the turbulence variable) is very large, and I think this is the reason for the crash. Probably mapField is generating this large values do to the fact that the boundaries are not exactly the same (the two meshes are generated with snappyHexMesh).
Is there a way to locate these few points and correct omega manually?
Thanks in advance
giorgianig is offline   Reply With Quote
Old   March 13, 2024, 13:19
Pedro Gouveia
unilord is on a distinguished road
Thanks in advance
Easiest way would be to use upwind divScheme for turbulence constants, and cellLimited Gauss Linear 1 for grad Schemes until it starts converging.
unilord is offline   Reply With Quote
Old   March 13, 2024, 13:28
Giorgio
The problem is that it diverges before starting the time loop. The limiting would kick-in after the first iteration.
Old   March 13, 2024, 13:57
Shravan
Severus is on a distinguished road
You have two options,
Option 1:
You can use limitFields functionObject: https://www.openfoam.com/documentati...mitFields.html
Note that the functionObject gets called in the beginning of the time loop, so it should work before things are computed in the first time step.
Check here: What is the trigger of the function objects??
Option 2:
If you can add piece of code inside your solver and recompile your solver, then I suggest you add something like this, before the time loop.
Lets say that the maximum allowable value of omega is max_value.
Then use
omega = min(omega,max_value);
Thanks
Severus is offline   Reply With Quote
limiting, mapfield
Y+ values exceed limit! James38 STAR-CCM+ 3 August 9, 2019 12:26
How to read variable values on a surface Comi Fluent UDF and Scheme Programming 3 April 3, 2019 22:33
3D equation, loading values for variable Cp from txt file with time-value columns AJAY BHANDARI OpenFOAM Programming & Development 11 January 1, 2016 06:16
How to monitor variable values of point at t=0 sec yunhee CFX 3 February 13, 2008 13:45
Tracing the variable values Neser25 CFX 0 November 7, 2005 11:26
