Octree Mesh
Old   February 24, 2024, 02:39
Default Octree Mesh
HS
ChaldExals is on a distinguished road
I would like to analyze a channel flow with Smagorinsky LES using OpenFOAM. But i want to do this on an octree mesh refining the upper and lower walls. Can you give any advice about how can I generate an octree mesh? Thank you in advance.
Regards,
ChaldExals is offline   Reply With Quote
Old   February 24, 2024, 08:30
HS
I tried blockMesh utility but I guess it does not work for such type of octree mesh. I found a similar mesh I want to generate. However, I don't know if OpenFOAM has a utility for this type of mesh.
channel flow, les, octree, smagorinsky
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 15:41
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
