January 28, 2024, 15:40 |
OpenFOAM-Flow around Cylinders
Jahangiri
Hi, I have some questions related to the simulation of flow around a cylinder with some differences.
Is it possible to increase the number of cylinders to approximately 100? Can I add motion to all these cylinders simultaneously at their end parts, considering they all have the same properties? And how? If I have all of these cylinders with specific locations within a constant and non-motion channel pipe, how should I import all STL files into OpenFOAM? Is there any important key in creating and importing of STL files which I must consider? For these conditions, mentioned above, which solver and libraries work best and provide accurate results?" Thanks in advance |
openfoam |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Simulation DNS for two phase flow in openFoam | ht2017 | OpenFOAM Running, Solving & CFD | 0 | December 8, 2020 05:50 |
What is the difference between taking mass flow rate from Openfoam and Parafoam? | Makkus | OpenFOAM Post-Processing | 0 | November 23, 2020 08:57 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
