January 14, 2024, 11:10 |
Foam fatal io error: cannot find file
Rep Power: 2 |
Hi, I am new to OpenFoam. I have installed openfoam2312 on ubuntu. I am trying to run lid-driven cavity flow. Following are the commands I used after opening ubuntu :
After executing above commands, I am getting an error - Code:
--> FOAM FATAL ERROR: (openfoam-2312) cannot find file "/usr/lib/openfoam/openfoam2312/tutorials/incompressible/icoFoam/cavity/cavity/system/system/controlDict" From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 626. |
January 15, 2024, 05:39 |
ONESP-RO
Rep Power: 5 |
1) The error message indicates that you are inside the system directory of your case, you need to be in the root level of the directory.
2) That's not how you're supposed to run openfoam tutorials. You should copy the tutorial to another writeable location and run it. Here is an example: Code:
mkdir -p $FOAM_RUN # Run this only once cd $FOAM_RUN # or simply use 'run' without quotes # copy the tutorial cp -r $FOAM_TUTORIALS/incompressible/icoFoam/cavity/cavity/ . cd cavity # Now, you can run blockMesh blockMesh
Don't keep making the same mistakes. Try to make new mistakes. |
January 15, 2024, 11:20 |
Rep Power: 2 |
Thank you! Followed the steps and now can execute blockmesh command without any errors.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
