December 21, 2023, 11:40 |
Using mpirun on OpenFOAM v10
Sidhartha Sahu
Rep Power: 5 |
Hello all,
I've written a custom solver on openfoam that calculates the Lyapunov exponents of a given flow and prints them into a text file. I wish to parallelise my run and I'm using the domain decomposition method is inbuilt into OpenFOAM. I call my solver in the run directory using the following commands; decomposePar mpirun -np 4 SC_LE_Analysis -parallel This command starts the calculation. But after completing a few time steps, I get the following error: Checkpoint 4 (Finished computing all 10 perturbations' growth) Starting Reorthonormalisation [0] #0 Foam::error:rintStack(Foam::Ostream&)[2] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [2] #1 Foam::sigFpe::sigHandler(int) at ??:? at ??:? [2] #2 ?[0] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [2] #3 in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 ?? in "/home/sid in "/home/sidsahu/sahu/OpeOpenFOAM/sidnFOAM/sidsahu-sahu-10/p10/platformlatforms/lis/linux64Gccnux64GccDPDPInt32Opt/bInt32Opt/binin/SC_LE_Analy/SC_LE_Analsis" ysis" [0] #4 [2] #4 ?? in "/home/sidsahu/OpenFOAM/sidsahu-10/platforms/linux64GccDPInt32Opt/bin/SC_LE_Analysis" [0] #5 in "/home/sidsahu/OpenFOAM/sidsahu-10/platforms/linux64GccDPInt32Opt/bin/SC_LE_Analysis" [2] #5 ?? in "/home/sidsahu/OpenFOAM/sidsahu-10/platforms/l in "inux64GccDPIn/home/sidsahut32Opt/bin/OpenFOAM//SC_LE_Anasidsahu-10/lysis" platforms/linux64Gc[0] #cDPInt32Op6 ?t/bin/SC_LE_Analysis" [2] #6 ? in "/lib/x86_64-linux-gnu/libc.so.6" [0] #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [2] #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [0] #8 in "/lib/x86_64-linux-gnu/libc.so.6" [2] #8 ?? in "/home/sidsahu/OpenFOAM/sidsahu-10/platforms/linux64GccDPInt32Opt/bin/SC_LE_Analysis" [sidsahu-HP-ZBook-15-G4:16740] *** Process received signal *** [sidsahu-HP-ZBook-15-G4:16740] Signal: Floating point exception (8) [sidsahu-HP-ZBook-15-G4:16740] Signal code: (-6) [sidsahu-HP-ZBook-15-G4:16740] Failing at address: 0x3e800004164 [sidsahu-HP-ZBook-15-G4:16740] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f3768442520] [sidsahu-HP-ZBook-15-G4:16740] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f37684969fc] [sidsahu-HP-ZBook-15-G4:16740] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f3768442476] [sidsahu-HP-ZBook-15-G4:16740] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f3768442520] [sidsahu-HP-ZBook-15-G4:16740] [ 4] SC_LE_Analysis(+0x448d0)[0x55b8e26b98d0] [sidsahu-HP-ZBook-15-G4:16740] [ 5] SC_LE_Analysis(+0x45db2)[0x55b8e26badb2] [sidsahu-HP-ZBook-15-G4:16740] [ 6] SC_LE_Analysis(+0x3d75d)[0x55b8e26b275d] [sidsahu-HP-ZBook-15-G4:16740] [ 7] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f3768429d90] [sidsahu-HP-ZBook-15-G4:16740] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f3768429e40] [sidsahu-HP-ZBook-15-G4:16740] [ 9] SC_LE_Analysis(+0x40915)[0x55b8e26b5915] [sidsahu-HP-ZBook-15-G4:16740] *** End of error message *** in "/home/sidsahu/OpenFOAM/sidsahu-10/platforms/linux64GccDPInt32Opt/bin/SC_LE_Analysis" [sidsahu-HP-ZBook-15-G4:16742] *** Process received signal *** [sidsahu-HP-ZBook-15-G4:16742] Signal: Floating point exception (8) [sidsahu-HP-ZBook-15-G4:16742] Signal code: (-6) [sidsahu-HP-ZBook-15-G4:16742] Failing at address: 0x3e800004166 [sidsahu-HP-ZBook-15-G4:16742] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f9ee7642520] [sidsahu-HP-ZBook-15-G4:16742] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f9ee76969fc] [sidsahu-HP-ZBook-15-G4:16742] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f9ee7642476] [sidsahu-HP-ZBook-15-G4:16742] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f9ee7642520] [sidsahu-HP-ZBook-15-G4:16742] [ 4] SC_LE_Analysis(+0x4493a)[0x563e7e0b093a] [sidsahu-HP-ZBook-15-G4:16742] [ 5] SC_LE_Analysis(+0x45db2)[0x563e7e0b1db2] [sidsahu-HP-ZBook-15-G4:16742] [ 6] SC_LE_Analysis(+0x3d75d)[0x563e7e0a975d] [sidsahu-HP-ZBook-15-G4:16742] [ 7] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f9ee7629d90] [sidsahu-HP-ZBook-15-G4:16742] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f9ee7629e40] [sidsahu-HP-ZBook-15-G4:16742] [ 9] SC_LE_Analysis(+0x40915)[0x563e7e0ac915] [sidsahu-HP-ZBook-15-G4:16742] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 0 on node sidsahu-HP-ZBook-15-G4 exited on signal 8 (Floating point exception). %%%%%%%%%%%% The section of SC_LE_Analsysis.C that prints the LEs into a text file is shown in SC_LE_AnalysisC.png I believe I'm doing the decomposition properly, I've also attached the decomposeParDict file in the attachements. I'm running this code on a machine with 4 cores. Sometimes I've noticed, the values printed into the text file on a parallel run are very different from that of a serial run. I'm not very well-versed with Parallelisation of code and would be grateful for your help |
January 3, 2024, 06:30 |
Please help!
Sidhartha Sahu
Rep Power: 5 |
Dear members,
I'd be grateful for your insights |
January 9, 2024, 15:13 |
Rep Power: 8 |
Division by zero? Check your code if it might be pissible to divide by zero. If yes, then you should write something like 1/(max(yourFormula, 1E-19)
January 16, 2024, 06:43 |
Unable to Pstream::gather(velocityField)
Sidhartha Sahu
Rep Power: 5 |
Hi Geth03,
Thanks for your reply. I figured the main source of error is the fact that I don't gather the details of my velocity field for ex. "U_d" from all the processors, before I perform a norm() operation or QR decomposition on U_d. Do you know how I can use Pstream::gather() or Pstream::gatherList() to gather U_d within my main code. P.S. This is almost like performing reconstructPar, but I need to do it within my main code. I'd really appreciate any help. Thank you. |
January 16, 2024, 14:56 |
Sidhartha Sahu
Rep Power: 5 |
I'd be grateful for your inputs
eigen package, mpirun error, openfoam 10.0 |
Error in codeStream @ openFoam v10 | Mohammadmz | OpenFOAM Programming & Development | 5 | February 22, 2023 02:24 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 12:50 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 04:19 |
Problem with mpirun with OpenFOAM | jiejie | OpenFOAM | 3 | July 7, 2010 20:30 |
