December 18, 2023, 16:38
Smagorinsky LES of Channel Flow Using PisoFOAM
HS
Hello All,
I am new to OpenFOAM and currently trying to run a test case of turbulent channel flow with Smagorinsky LES (using pisoFoam solver). My geometry domain is 6.4m*1m*2.4m. Bulk reynolds number in terms of half channel height is 125000. I am using a simple mesh by using 50,40, and 40 cells in x,y,and z directions respectively. I am applying streamwise and spanwise cyclic boundary conditions so that i can simulate a fully developed flow. The simulation runs without any error. However, the pressure in the entire flow domain is almost 0 (around 10^-8). There should be some pressure gradient. Also, i can't get any visible eddies in the flow field. I know my mesh isn't that fine but i guess there should be something to see. Could you help me with this situation? Initial conditions for p,U, and nut are given as can be seen below.
| \\ / O peration | Version: v2012 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type cyclic;
outlet
type cyclic;
upperWall
type zeroGradient;
lowerWall
type zeroGradient;
leftWall
type cyclic;
rightWall
type cyclic;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (3.7 0 0);
boundaryField
inlet
type cyclic;
outlet
type cyclic;
upperWall
type noSlip;
lowerWall
type noSlip;
leftWall
type cyclic;
rightWall
type cyclic;
FoamFile
version 2.0;
format ascii;
object nut;
dimensions [0 2 -1 0 0 0 0];
boundaryField
inlet
type cyclic;
outlet
type cyclic;
upperWall
type zeroGradient;
lowerWall
type zeroGradient;
leftWall
type cyclic;
rightWall
type cyclic;
I used meanVelocityForce in fvSolutions as seen below.
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object fvOptions;
momentumSource
type meanVelocityForce;
active yes;
meanVelocityForceCoeffs
selectionMode all;
fields (U);
Ubar (3.7 0 0);
Thank you in advance.
Regards,
