Integrating sixDoFRigidBodyMotion and rotatingMotion in OpenFOAM |
December 10, 2023, 21:32 |
Perseus
Hello everyone,
I'm a newcomer to OpenFOAM, and I'm planning to simulate the 2D Vortex-Induced Vibration (VIV) phenomenon of an ellipse using the overPimpleDyMFoam solver in OpenFOAM V2306. In my setup, I want to allow the ellipse to freely oscillate in the vertical inflow direction and simultaneously apply a constant rotational angular velocity to the ellipse. I plan to use sixDoFRigidBodyMotion to simulate the free oscillation and rotatingMotion under solidBody to simulate the constant rotational angular velocity. However, I'm struggling to integrate these two motions seamlessly. Below is my dynamicMeshDict file settings: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicOversetFvMesh; solver multiSolidBodyMotionSolver; solvers { viv { motionSolver sixDoFRigidBodyMotion; patches (cylinder); innerDistance 100; outerDistance 101; report on; mass 2; centreOfMass (0.0 0.0 0.0); momentOfInertia (1 1 1); g (0 0 0); rho rhoInf; rhoInf 1; solver { type Newmark; } constraints { yLine { sixDoFRigidBodyMotionConstraint line; direction ( 0 1 0); } rotation { // sixDoFRigidBodyMotionConstraint orientation; sixDoFRigidBodyMotionConstraint axis; // centreOfRotation (0 0 0); axis (0 0 1); } } } overset_internal { motionSolver solidBody; solidBodyMotionFunction rotatingMotion; rotatingMotionCoeffs { origin (0. 0. 0.); axis (0 0 1); omega 1.570; } } } Thank you! |
rotate body, sixdofmotionsolver, solidbodymotion, viv |
I get this error in OpenFOAM when I run my case (mpirun, with pimpleFOAM) | brateboj | OpenFOAM Running, Solving & CFD | 0 | July 12, 2022 10:58 |
Combining rotatingMotion + displacementLaplacian | egebat7 | OpenFOAM Running, Solving & CFD | 4 | September 20, 2021 10:07 |
Dynamic Mesh issue when coupling OpenFOAM with FSI | ConorMD | OpenFOAM Running, Solving & CFD | 0 | May 12, 2020 06:19 |
Problem with rotatingMotion OpenFOAM 2.2.2 | Naruto | OpenFOAM Running, Solving & CFD | 7 | November 28, 2013 10:03 |
Rotation around a local axis (OpenFOAM 2.01) | Naruto | OpenFOAM Pre-Processing | 0 | July 29, 2013 13:00 |
