Extracting nodal forces on boundary in OpenFoam |
Rocco
Rep Power: 9 ![]() |
Hello!
I am fairly new to OpenFoam and I'm trying to understand if the following feature exists. I'd like to extract total forces (resulting from pressure and shear) on the nodes of a chosen boundary at the end of a steady run. I am already able to directly extract pressures and shears and the normal to the element but I'd like to know if the already integrated (over the relative surface) forces can be extracted somehow. Thanks in advance for any hint about this. Best, Rocco |
Yann
Rep Power: 27 ![]() |
In the ESI-OpenCFD branch (openfoam.com), you can use the force function object with the writeFields flag in order to write forces as a scalar field. https://doc.openfoam.com/2306/tools/...forces/forces/ I don't know if there is an equivalent feature in the foundation branch (openfoam.org). Regards, Yann |
forces, openfoam, output |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
