construction of two-phase shockWave in compressibleInterFoam
Old   November 21, 2023, 04:20
Default construction of two-phase shockWave in compressibleInterFoam
ali
A_wick is on a distinguished road
hello every one.
i want to make a 1D and two-phase (water-gas) testCase of shockwave but the interface is not deleted so water and gas does not mix and they stay still untile the end.
my solver : (compressibleInterFoam)
the properties for water and gas are as follows :
for gas :
adiabatic coefficient :1.4
wan der waals coefficient : 0
surface tension : 0.0725
ambient Temperature : 293.15 K
mu : 0
R = 287
for water :
surrounding Pressure : 101315 pa
rho = 998.206
gamma = 7.15
tait Pressure = 3046e5
mu= 0
the boundary condition of the velocity in the walls is : noSlip
at the end, my testCase has been uploaded. please help me to solve the problem thats mean : remove the interFace and mix the water with gas to get the correct pressure diagram. thanks
File Type: zip shockWave_AD_blockmesh_mokhtasatVasat.zip (22.8 KB, 1 views)
A_wick is offline   Reply With Quote
iteration questions in discrete phase iknowjesus FLUENT 4 March 13, 2015 07:07
Adding an energy source term to a phase with reactions lxlxlxt Fluent Multiphase 0 February 10, 2014 21:42
multi phase flow with chemical reactions in one phase Habibfateh OpenFOAM Programming & Development 0 February 10, 2014 08:33
Derive fixed number of phase from clone () in multiphaseEulerFoam Solver Aj Nair OpenFOAM Programming & Development 0 December 16, 2013 21:41
Extract primary phase thread in VOF with 3 phases Eric FLUENT 2 July 7, 2011 03:22
