Relaxation factor intervals
Old   October 29, 2023, 17:58
Default Relaxation factor intervals
chemotkbilo is on a distinguished road
I am trying to vary the velocity relaxation factor between 0.2 and 0.5 .
Here is my code, what is wrong with it
relaxationFactors
    // Conservative settings to solve reliably on bad
    // meshes
    equations
        UEqn               table ((0 0.2) (0 0.5));
        k               0.5;
        omega           0.5;
    fields
        p               0.3;
        U            table ((0 0.2) (0.5 0.5));
I received the following error
HTML Code:
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 116 the word 'table'
file: /home/openfoam/system/fvSolution/relaxationFactors/equations/U at line 116.
    From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&)
    in file lnInclude/Scalar.C at line 101.
FOAM exiting
The entire case works fine with no issue with an exact velocity relaxation factor such as state U 0.6;
But I would like to vary it between intervals.
chemotkbilo is offline   Reply With Quote
Old   October 30, 2023, 04:12
Yann
Yann will become famous soon enoughYann will become famous soon enough
What OpenFOAM version are you using?
Regards,
Yann
Yann is offline   Reply With Quote
Old   October 30, 2023, 13:16
Regards,
Yann
Version 11.0
Old   October 31, 2023, 04:30
Yann
AFAIK you cannot use time variable relaxation factors in the foundation branch (openfoam.org, OpenFOAM 11).
It is only possible in the OpenCFD branch (openfoam.com) since version v2112 (see release notes here)
Yann
solids4foam solidSolver fixed vs. Aitken relaxation Xulia OpenFOAM CC Toolkits for Fluid-Structure Interaction 10 April 13, 2023 07:34
Lets talk about relaxation factor optimization chriss85 OpenFOAM Running, Solving & CFD 35 June 21, 2019 10:54
Long output in terminal. ssa_cfd OpenFOAM Running, Solving & CFD 1 March 18, 2019 06:25
About equation relaxation chriss85 OpenFOAM Running, Solving & CFD 1 May 2, 2017 20:52
Relaxation and convergence sammi Phoenics 0 March 20, 2008 04:32
