Regarding decomposePar blowoff while running openfoam |
September 20, 2023, 05:17 |
ijaz fazil
Rep Power: 13 |
Hi all,
I'm modelling urban airflow using buoyantsimplefoam. We are using actual terrain instead of flat terrain. I created mesh using the following command decomposePar mpirun -np 64 snappyHexMesh -parallel -overwrite reconstructParMesh -constant checkMesh Log snappyhexmesh ends with Writing mesh to time constant Wrote mesh in = 350.41 s. Mesh snapped in = 2558.65 s. Checking final mesh ... Checking faces in error : non-orthogonality > 60 degrees : 0 faces with face pyramid volume < 1e-13 : 0 faces with face-decomposition tet quality < 1e-15 : 0 faces with concavity > 80 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.05 : 0 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.02 : 0 faces on cells with determinant < 0.001 : 0 Finished meshing without any errors Finished meshing in = 5887.69 s. End Finalising parallel run After reconstructParMesh and while checking mesh I get one quality failed Checking geometry... Overall domain bounding box (0 0 -5.739853e-14) (5500 5500 1000) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.53412e-16 -3.11233e-15 1.939486e-13) OK. Max cell openness = 4.438246e-16 OK. Max aspect ratio = 9.576651 OK. Minimum face area = 0.007753621. Maximum face area = 421.7486. Face area magnitudes OK. Min volume = 0.05158672. Max volume = 6093.245. Total volume = 3.007628e+10. Cell volumes OK. Mesh non-orthogonality Max: 60.00908 average: 3.920135 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 7.219928, 10 highly skew faces detected which may impair the quality of the results <<Writing 10 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. I'm not sure why mesh fails after reconstructing When I run the simulation with single core the simulation starts without error But while decompose again and run parallel my decomposition fails with errors like --> FOAM FATAL IO ERROR: error in IOstream "/home/users/nus/ijaz01/PinnacleCaseStudy1_buoyantsimplefoam/20230920/case2_reducedmesh/simulation1/processor16/constant/polyMesh/faces" for operation Foam::Ostream& Foam:perator<<(Foam::Ostream&, int64_t) file: /home/users/nus/ijaz01/PinnacleCaseStudy1_buoyantsimplefoam/20230920/case2_reducedmesh/simulation1/processor16/constant/polyMesh/faces at line 2867957. or [2] --> FOAM FATAL ERROR: [2] Cannot find file "points" in directory "polyMesh" in times "0" down to constant my decomposePar dict is as below numberOfSubdomains 8; method scotch; simpleCoeffs { n ( 2 2 2 ); delta 0.001; } hierarchicalCoeffs { n ( 1 1 1 ); delta 0.001; order xyz; } manualCoeffs { dataFile ""; } distributed no; roots ( ); I'm using openfoam 1912, is there any issue with decomposition and reconstructPar that causes error while trying to run the simulation in parallel? |
September 20, 2023, 05:49 |
Yann
Rep Power: 27 |
If you want to compare your mesh quality before/after reconstructing your mesh, you should rather run checkMesh twice. Something like: Code:
decomposePar mpirun -np 64 snappyHexMesh -parallel -overwrite mpirun -np 64 checkMesh -parallel reconstructParMesh -constant checkMesh 10 faces with a skewness about 7 is usually not a big deal for the simulation. (On complex geometry it might not always be possible to totally get rid of skewed faces). Code:
[2] --> FOAM FATAL ERROR: [2] Cannot find file "points" in directory "polyMesh" in times "0" down to constant Something seems to be off about the information your provide: you run snappy on 64 cores, but your decomposeParDict mentions 8 subdomains only . Code:
--> FOAM FATAL IO ERROR: error in IOstream "/home/users/nus/ijaz01/PinnacleCaseStudy1_buoyantsimplefoam/20230920/case2_reducedmesh/simulation1/processor16/constant/polyMesh/faces" for operation Foam::Ostream& Foam:perator<<(Foam::Ostream&, int64_t) file: /home/users/nus/ijaz01/PinnacleCaseStudy1_buoyantsimplefoam/20230920/case2_reducedmesh/simulation1/processor16/constant/polyMesh/faces at line 2867957. And one last thing: reconstructing the mesh is optional. You can run a whole case and post-process it without having to reconstruct anything. Hopes this helps, Yann |
buoyantsimplefoam, checkmesh, decomposepar, openfoam1912, reconstructparmesh |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 19:00 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
