August 18, 2023, 04:55 |
Quadruplicate a baffle in OpenFOAM11
Seungtae Kim
Rep Power: 3 |
Hello foamer,
I'm struggling while use activeBaffleVelocity and activePressureForceBaffleVelocity boundary condition in OF11 To use it, I needed 4 baffles which share the geometry and position(2 for cyclic pair and 2 for merged wall) Thanks to the awesome tutorial from Holzmann CFD, I can do this in OF from ESI group However, when I moved into OF11 from OpenFOAM Foundation, I found out quadruplicate parts in createBafflesDict dosen't work since Foundation version require strictly require for owner and neighbor pair per one facezone(and I guessed that's why Holzmann CFD dose not upload tutorial for Foundation version) As far as I tried
Since both activeBaffleVelocity and activePressureForceBaffleVelocity boundary condition are still in OF11 I think there must be a clever workaround. Is there any succeed in OpenFOAM Foundation that utilize activeBaffleVelocity or activePressureForceBaffleVelocity boundary condition? |
June 25, 2024, 10:20 |
Matias Alberto Aguirre
Rep Power: 3 |
Hello Seungtae,
Could you find any solution to this problem? I'm trying to apply the same BC and I can't make it work either. Cheers, Matias. |
activebafflevelocity, createbaffles |
Some confusions about baffle faces | ruanyg968tf | OpenFOAM Programming & Development | 0 | May 17, 2022 05:17 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Problems using createBaffles to create a 3D thermal baffle | zfaraday | OpenFOAM Running, Solving & CFD | 10 | September 6, 2017 17:07 |
[snappyHexMesh] handling of baffle regions or surfaces with zero thickness with snappyHexMesh | StSchiff | OpenFOAM Meshing & Mesh Conversion | 5 | March 8, 2017 09:45 |
Boundary baffle error 258 | Nalleli | Siemens | 2 | November 19, 2006 13:14 |
