Shaik Asif
Rep Power: 6 ![]() |
Dear OpenFoamers,
I am running a mixer vessel case with water as continuous phase and air bubbles entering it as particles. I defined a MRF region around the impeller to account for the rotation of the impeller. But the effects of MRF rotation is not showing in liquid phase (ex: U.water plots). Does denseParticleFoam only solves the motion of particles and does not consider the rotation effects on liquid? Thanks for the response in advance. |
Thomas Sprich
Rep Power: 11 ![]() |
Hi Shaik,
Did you find an answer to this? I am trying something similar and I also have the feeling that the rotation is not handled. Did you find any solution? I really want to avoid using mesh motion to solve for the rotation. Thanks, Thomas |
denseparticlefoam, dpmfoam cfdem, lagrangian bubble, multiphase flow, particle clou |
MRF not working with chtMultiRegionFoam | nikoscham | OpenFOAM Running, Solving & CFD | 2 | January 25, 2023 06:00 |
Unsteady solver + MRF (=frozen rotor) approach | xxxx | Main CFD Forum | 7 | December 2, 2014 09:34 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
MRF Solver fan simulation - problem | sivakumar | FLUENT | 0 | February 15, 2013 03:26 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
