How to Model Non Newtonian Laminar Flow?
Old   July 3, 2023, 15:42
Default How to Model Non Newtonian Laminar Flow?
Prayan
pranay10 is on a distinguished road
Hello Experts,
I am studying the flow of Non-Newtonian Fluids in a Sinusoidal Channel as part of an ongoing research using OPENFOAM. I am new to this software.
Different models of viscosity like Hershey-Bulkey, Cross-Power Law, Power Law, etc needs to be examined.
The flow is supposed to be laminar. However, there are no solvers in openfoam that solves Non-Newtonian Laminar flows.
What solver can be used in this case?
pranay10 is offline   Reply With Quote
Old   July 4, 2023, 04:46
Yann
Yann will become famous soon enoughYann will become famous soon enough
For incompressible flows, you can choose between Newtonian and Non-Newtonian models in the transportProperties file (or physicalProperties, depending on the OpenFOAM version you are using)
And you can also switch between turbulent or laminar flow in pretty much any solver, so I guess any incompressible solver could work.
Do you need steady or transient simulation ?
What OpenFOAM version are you using ? (if not sure, try typing the foamVersion command)
Regards,
Yann
Yann is offline   Reply With Quote
Old   July 4, 2023, 08:12
Prayan
I am using OF2212.
Also, I need steady state and not transient state.
Old   July 4, 2023, 10:06
Yann
Then simpleFoam sounds good.
You can have a look to the TJunctionArrheniusBirdCarreauTransport tutorial to have an example of a setup using a non-Newtonian fluid. It's a pimpleFoam tutorial, so it's transient, but you should be able to use the same transporProperties file on a simpleFoam case.
Cheers,
Yann
Old   July 5, 2023, 02:52
Prayan
Thank You very much.
Also, may I know where can I find more such files for non-newtonian? Can you provide more if possible?
Old   July 5, 2023, 04:35
Yann
Generally speaking, in such situation you can use the banana trick.
In the transportProperties file, define "banana" as transportModel and run the solver. It will throw you an error and give you a list of valid transport models.
You can then search for those transport models in the source code and/or the tutorials to see how to use it.
For instance, it should lead you there in the source code: https://develop.openfoam.com/Develop...iscosityModels
Cheers,
Yann
fluid dynamics, non newtonian power law, research, viscosity, viscosity model
unable to run dynamic mesh(6dof) and wave UDF shedo Fluent UDF and Scheme Programming 0 July 1, 2022 18:22
laminar flow in one zone and kEpsilon model in the other zone. super1 OpenFOAM 3 January 15, 2017 11:44
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Convergence of laminar flow model for high Re Chander Main CFD Forum 0 December 16, 2010 06:10
Laminar flow in species transport model? Neha Rao FLUENT 7 February 25, 2006 03:23
