Rep Power: 0 ![]() |
I have been trying to couple the temperature across two boundaries almost as an expression. One boundary is considered as an inlet with with a fixedValue temperature type that should be linked to an outlet boundary of adiabatic (zeroGradient) condition. Essentially the inlet temperature should be half of the average temperature recorded on the outlet surface. I tried the following, however this code does not work. Any guidance would be very much appreciated. HTML Code:
\T: Supply { type zeroGradient; } Return { type fixedValue; value $Supply/(0.5); } \U: Return { type flowRateInletVelocity; volumetricFlowRate 0.625; // m3/s value uniform (0 0 0); } Supply { type flowRateOutletVelocity; volumetricFlowRate 0.625; // m3/s value uniform (0 0 0); } |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
