Franco
Rep Power: 5 ![]() |
Hello everyone,
is it possibile to uses the SRF option in a coupled FSI simulation exploiting solids4foam? For example, if a would like to simulate a flexible (deformable) cylinder immersed in a flow stream, and I want to imposte to that cylinder a rotation (that should be summed to the deformations coming from the fluid pressure), is it possible to use a rotating reference frame approach? I have noticed that in order to change the fluid solver in solids4foam, the fluidModel should be changed (for example in the fluidProperties dict the icoFluid model is recalled). However, under my solids4foam/src folder, I cannot find the fluidModels folder, so I do not have any idea where to start to create a simpleSRFfluid dict. Could someone help me? All the best. Franco |
