How to run the case with #codeStream to generate the initial condition in fe41
Old   June 12, 2023, 10:43
Default How to run the case with #codeStream to generate the initial condition in fe41
young4of
Youngxl is on a distinguished road
Hi everyone!
Recently I was using codeStream to generate the initial conditions I wanted, but after using solids4foam &>log, I got the following result, where the log file ends with the is up to date. The detail is as follow.
_97f89ca9e8c9e14ee938b417e0c5322af4cd6fc2/../platforms/linux64GccDPInt32Opt/lib/libcodeStream_97f89ca9e8c9e14ee938b417e0c5322af4cd 6fc2.so' is up to date.
And the terminal shows segmentation fault (core dumped). I really want to know the operation flow of using codestream in foam-extend4.1. Is there any difference between it and other versions? What I use is that blockMesh first and then the solver solid4Foam & > log directly. But it doesn't seem to make computing work.
Really hope you could give me some suggestions.
Thanks !
Young
Youngxl is offline   Reply With Quote
codestream, foam extend 4.1, solids4foam
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
