Local fixed time step in one equation within the whole domain |
MrXuxu
Rep Power: 6 ![]() |
Hello everyone,
I’m performing aeroacoustics transient solver with local time step or two physical time. The process of the simulation is showed as following: 1)UEqn.H 2)pEqn.H (which is same as the pisoFoam and the two is controlled by larger time step T_flow) 3) aco.H : the aco.H reads some information from the flow field and doesn’t return results to the flow field. In this process, the time step of aco.H, I hope, is 10 times smaller of T_flow(T_aco = 0.1T_flow) and the value “10 times” is the fixed value that I can input. Therefore, my problems is how to implement it T_T and I have no clues on it. To be more detailed, how to perform time-control in OpenFOAM ? Thank you very much if you can give me a hand! |
Tobias Holzmann
Rep Power: 51 ![]() ![]() ![]() |
Hey,
simply spoken:
if (runTime.value() % 10 == 0) { // Execute all from pisoFoam } acoustic.eqn; Cheers.
Keep foaming, Tobias Holzmann |
MrXuxu
Hello Tobi,
I'm grateful to your helping and it works very well Best wishse! Memorise |
lts |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 02:05 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
