Parallel running stops when sample point sets z=(0,0) using LES
Old   May 31, 2023, 11:57
Default Parallel running stops when sample point sets z=(0,0) using LES
Teresa Sun
Teresa Sun is on a distinguished road
Dear Foamer,
Can anyone tell me what's going on?
Simulation case: circular cylinder at Re=3900 using LES with the customized model (minimum-dissipation model).
The problem happened when sampling along the central line in a streamwise direction, i.e., y=(0,0) and z=(0,0)
It works with no problem while running on a single core. But the simulation stops while running in parallel on 128, 64 and 32 cores using simple or scotch decomposition methods. There is no error message and the simulation doesn't exit.
This problem can be solved by changing z=(0,0) to z=(0,1e-5), (using a small non-zero value).
Why this problem occurs and why it is solved in this way?
controlDict
|  \\    /   O peration     | Version:  6                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      controlDict;
application     RKSymLESFoam;
//startFrom       startTime;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         500;
deltaT          0.002;
writeControl    adjustableRunTime;
writeInterval   20;
purgeWrite      50;
writeFormat     ascii;
writePrecision  8;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
//Not implemented in PISO
adjustTimeStep  yes;
maxCo           0.5;
maxDeltaT       0.1;
functions
    inMassFlow
        type            surfaceFieldValue;
        libs            ("libfieldFunctionObjects.so");
        enabled         true;
        timeStart       100;
        writeControl    outputTime;
        writeInterval   1;
        log             true;
        writeFields     false;
        regionType      patch;
        name      in;
        operation       sum;
        fields
            phi
    outMassFlow
        enabled         true;
        timeStart       100;
        writeInterval   1;
        log             yes;
        writeFields     false;
        regionType      patch;
        name            out;
        operation       sum;
        fields
            phi
    fieldAverage
        type            fieldAverage;
        enabled         true;
        timeStart       100;
        writeControl    timeStep;
        //writeInterval 100;
        fields
            U
                mean        on;
                prime2Mean  on;
                base        time;
            p
                mean        on;
                prime2Mean  on;
                base        time;
    forceCoeffs_object
        // rhoInf - reference density
        // CofR - Centre of rotation
        // dragDir - Direction of drag coefficient
        // liftDir - Direction of lift coefficient
        // pitchAxis - Pitching moment axis
        // magUinf - free stream velocity magnitude
        // lRef - reference length
        // Aref - reference area
        type forceCoeffs;
        libs ("libforces.so");
        //patches ("body1" "body2" "body3");
        patches ("cylinder");
        pName p;
        Uname U;
        rho rhoInf;
        rhoInf 1.0;
        //// Dump to file
        log true;
        CofR            (0.0 0 0);
        liftDir         (0 0.5 0);
        dragDir         (0.5 0 0);
        pitchAxis       (0 0 0.5);
        magUInf         1.0;
        lRef            1.0;         // reference lenght
        Aref            3.1415926;         // reference area 1 for 2d
        timeStart       100;
        writeInterval   1;
    minmaxdomain
        type            fieldMinMax;
        enabled         true;
        mode            component;
        timeStart       100;
        writeInterval   1;
        log true;
        fields (p U nut);
    turbulenceFields1
        type            turbulenceFields;
        libs            (fieldFunctionObjects);
        fields          (I devReff nut nuEff L);
        //fields          ( k  R I devReff nut nuEff L);
        executeControl  writeTime;
        timeStart       100; // approx 2x flow-throughs
        writeControl    writeTime;
    Q1
        type            Q;
    momErr
        type            momentumError;
    vorticity1
        type            vorticity;
    sample
        type                sets;
        libs                (sampling);
        interpolationScheme cellPoint;
        setFormat           raw;
        //extract the profile along y axi x=constant,z=0m
        Ymin                    -3;
        Ymax                    3;
        Z                       0;
        D                       1;
        yPoints                 80;
        sets
            X_by_D_1_06
                type    face;
                axis    y;
                start   (#eval{1.06 * $D} $Ymin $Z);
                end     (#eval{1.06 * $D} $Ymax $Z);
                nPoints $yPoints;
            X_by_D_1_54
                type    face;
                axis    y;
                start   (#eval{1.54 * $D} $Ymin $Z);
                end     (#eval{1.54 * $D} $Ymax $Z);
                nPoints $yPoints;
            X_by_D_2_02
                type    face;
                axis    y;
                start   (#eval{2.02 * $D} $Ymin $Z);
                end     (#eval{2.02 * $D} $Ymax $Z);
                nPoints $yPoints;
            X_by_D_6
                type    face;
                axis    y;
                start   (#eval{6.0 * $D} $Ymin $Z);
                end     (#eval{6.0 * $D} $Ymax $Z);
                nPoints $yPoints;
            X_by_D_7
                type    face;
                axis    y;
                start   (#eval{7.0 * $D} $Ymin $Z);
                end     (#eval{7.0 * $D} $Ymax $Z);
                nPoints $yPoints;
            X_by_D_10
                type    face;
                axis    y;
                start   (#eval{10.0 * $D} $Ymin $Z);
                end     (#eval{10.0 * $D} $Ymax $Z);
                nPoints $yPoints;
            X_by_D_centralLine
                type    midPoint;
                axis    x;
                start   (-1   0 0);
                end     (20.0 0 0.00001);
                nPoints 200;
        fields
                k nut p pPrime2Mean R I devReff Q
                vorticity
                U UMean UPrime2Mean grad(U)
fvSchemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    //default         Euler;
    default         backward;
    //default         CrankNicolson 0.0;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    //default        leastSquares;
    //default        cellMDLimited leastSquares 0.5;
    //default        cellMDLimited Gauss linear 1;
    //grad(U)        cellMDLimited Gauss linear 1;
divSchemes
    default         none;
    div(phi,U)      Gauss linear;
    //div(phi,U)      Gauss filteredLinear;
    //div(phi,U)      Gauss limitedLinearV 1;
    //div(phi,U)      Gauss LUST unlimitedGrad(U);
    //div(phi,U)      Gauss linearUpwind grad(U);
    //div(phi,U)      Gauss linearUpwindV default;
    //div(phi,U)      Gauss linearUpwindV grad(U);
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
    //div(phi,k)                Gauss linearUpwind default;
    //div(phi,omega)    Gauss linearUpwind default;
    //div(phi,k)                Gauss linear;
    //div(phi,omega)    Gauss linear;
    //div(phi,k)                Gauss upwind;
    //div(phi,omega)    Gauss upwind;
laplacianSchemes
     default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited 1;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0;
        minIter         2;
    p
        solver           GAMG;
        tolerance        1e-6;
        relTol           0.01;
        smoother         GaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        cacheAgglomeration on;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 100;
        mergeLevels      1;
        minIter         2;
    pFinal
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0;
        minIter         3;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-08;
        relTol          0;
        minIter         3;
    U
        type            coupled;
        solver          PBiCCCG;
        tolerance       (1e-08 1e-08 1e-08);
        relTol          (0 0 0);
    UFinal
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
        minIter         3;
PISO
    nCorrectors     2;
    nNonOrthogonalCorrectors 1;
    pRefCell        0;
    pRefValue       0;
Teresa Sun is offline   Reply With Quote
Old   May 31, 2023, 12:06
Unhappy
Teresa Sun
Intended to post this in the sub-forum OpenFOAM Running, Solving & CFD.
How to edit it or delete
les, parallel running, sample
[snappyHexMesh] reconstructPar after running snappyhexmesh in parallel fidu OpenFOAM Meshing & Mesh Conversion 11 October 20, 2020 10:01
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 05:59
Running in parallel Djub OpenFOAM Running, Solving & CFD 3 January 24, 2013 17:01
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
