Motorbike Tutorial Error: coeffs=0
Old   May 31, 2023, 07:40
Post Motorbike Tutorial Error: coeffs=0
TAZ
L T
TAZ is on a distinguished road
Hey there,
i'm getting into OpenFoam (using OF10) and after following few of József Nagy tutorials (god bless this guy) i tried some stuff myself, everything kinda worked until i tried the motorbike tutorial. here's the link: https://www.youtube.com/watch?v=1C4Av_yCfpw
I tried multiple times following the tutorials i foun on YT etc, but no results.
the mesh seems fine, i don't get any error and i can see it using paraview. it seems like there is something wrong either with the initial conditions or with the solver, as at every iteration i get CD, CL, CM all equal to 0 (the velocity is the pre defined 20m/s value).
after building the mesh (blockmesh + surfaceFeatures + snappyHexMesh) and checking with the dummy file in paraview that the mesh is there, i copied everything that's in folder 0 to folder 3 (replacing what is with the same name)
then launching the simulation with simpleFoam, that's the result:
Cm=0
Cd=0
Cl=0
Cl(f)=0
Cl(r)=0
also it seems that the simulation does not converge, as when solving for Ux, it reaches 1000 iterations and then moves on (attached image).
of course when opening paraview, i don't see any pressure or velocity field.
Also, when opening the U or P files, they look weird, likely they are somehow corrupt or something.
it's probably some extremely dumb mistake i'm making, but really cant figure it out!
Attacched:
snappyHexMesh terminal printout
simpleFoam terminal printout
end simulation terminal printout
last timestep result folder
initial conditions (made up) folder
initial_conditions.zip
500.zip
TAZ is offline   Reply With Quote
Old   August 24, 2023, 14:58
Default Did you find any solution to this?
Adam
cfd_site_m is on a distinguished road
Same issue
Checked initial condition , p and U files still no change, all coefficients values are 0.
cfd_site_m is offline   Reply With Quote
Old   September 2, 2023, 03:42
Default Solved
Adam
Number of cells/points in mesh and field don't match
I followed solution by aghora17
1: surfaceFeatureExtract
2:blockMesh
3: In controldict file set the startfrom to latestTime
4: copy polymesh, p,U,k, nut and omega files to dir 1,2 and 3. (do not replace them the existing ones just paste the ones that don't exist)
(extendedFeatureEdgeMesh as well if you are facing issue)
From what I could gather the issue is number of cell discrepancy. And it's supposed to skip the step 0 during solving case and solve from latestTime. Openfoam v6 has startfrom set to laterTime but openfoam v11 has set it to startTime so it'll start from 0.
Also change the 0 file from 0.orig to 0
Old   September 5, 2023, 10:05
Federico Nahuel Ramírez
fedenr is on a distinguished road
Have you tried using the "-overwrite" flag when meshing instead of copying the data from one folder to another?
It would be:
snappyHexMesh -overwrite
Then you should have the mesh in the polyMesh folder in constant instead of at new "iteration" folders.
If this doesn't work I would take a look at the name of the boundaries (at polyMesh or using paraview) and then check de initial conditions and forceCoeffs dictionary.
fedenr is offline   Reply With Quote
motorbike tutorial, openfoam 10
flowVelocity and drag coefficient issue in the motorBike tutorial jan90300 OpenFOAM Running, Solving & CFD 3 April 28, 2021 02:22
Choosing l in external aero simulation & nu used in motorbike tutorial edomalley1 OpenFOAM Running, Solving & CFD 0 November 28, 2017 13:39
[snappyHexMesh] How to eliminate skew faces in motorbike tutorial sharkbait_au OpenFOAM Meshing & Mesh Conversion 2 July 17, 2015 12:54
[snappyHexMesh] Proper y+ in boundary layer on lowerWall - motorBike tutorial petr.f. OpenFOAM Meshing & Mesh Conversion 2 June 9, 2015 06:47
[snappyHexMesh] Tweaked motorbike tutorial doesn't show my icosphere mfiandor OpenFOAM Meshing & Mesh Conversion 0 October 9, 2011 19:39
