Rohan
Rep Power: 3 ![]() |
Greetings,
im trying to solve for a finite wing of Naca4415 airfoil data using rhoSimpleFoam. the initial boundary conditions are 0.4M (velocity), and 0 angle of attack. The turbulence model used in k-omega and the flow is compressible. im getting negative coefficients of lift and drag even though i have set the velocity, lift and drag dir based on the coordinate system of the geometry. Tried various things yet nothing works, not sure if im missing something. kindly help me with this, regards, Rohan |
Rohan
This is the force coeffs code
forces { type forceCoeffs; libs ("libforces.so"); writeControl timeStep; writeInterval 1; patches ("wingbottom"); patches ("wingtip"); patches ("wingtop"); rhoInf 1.2; liftDir (0 1 0); dragDir (1 0 0); CofR (0 0 0); // Coefficient of rotation pitchAxis (0 0 1); magUInf 136.119; lRef 1; // Ref length Aref 1; // Ref area } |
Yann
Rep Power: 27 ![]() |
Not sure what is going on, but your patches definition is wrong:
patches ("wingbottom"); patches ("wingtip"); patches ("wingtop"); Code:
patches (wingbottom wingtip wintop); Yann |
Rohan
ohhh, i was thinking lift usually acts on bottom surface of the wing so i need to include wingbottom patch as well. i will try the way you have shown to include all surfaces and check.
Thank you very much, Rohan |
Yann
I think there is a misunderstanding: I mean on your forceCoeffs definition, the last "patches" line override the previous ones so the way your function is defined, it only uses wingtop in the calculation instead of the whole wing (wingtop+wingbottom+wingtip)
Yann |
Rohan
yes, i made a mistake in defining patches, so the alternative way to include them which you have suggested, [patches (wingbottom wingtip wintop);] will this work for my case?
Thank you, Rohan |
Yann
Try and see
![]() Check patches names, liftDir and dragDir. Yann |
Rohan
i have tried that statement for patches, the negative Cl, Cd is resolved but the Cl, Cd values are quite high like Cl is ranging around 4.83e+01, Cd around 8,71e-01. i have also tried defining only wingtop as a patch but the cl cd values are all zeroes in this case.
#9 |
Yann
Does your reference length and area make sense?
About patches, there is no doubt: if you want to compute the coefficient of your profile you need to include the whole profile. |
#10 |
Rohan
yes the chord length is 0.046 and the ref area value was calculated based on chord length and span. i will recheck it again anyhow. What units does openfoam consider, for lref and aref, i think there might be a problem there. So i have calculated lref and aref like this (lref = chord length, aref = chord length*span) is this correct or is there any other way to calculate them
Thank you |
#11 |
Yann
Both lRef and Aref were set to 1 in your first post, I guess you fixed it afterward?
#12 |
Rohan
ohh yes i fixed it later, so lref = chord length and aref = chordlength*span, is this the right way to set the values or is there any other way to find them. and i assumed openfoam takes units as m or m^2 for these values, is this where th problem might be?
#13 |
Yann
Sounds good yes. Have you check your simulation results ? Did it converge ? Velocity and pressure fields make sense?
#14 |
Rohan
Yes the velocity fields and pressure contours made sense however I'm not sure about the values, as I said cl and cd values are quite high, so I'm not sure about it, I'll try a different case taking a new wing and calculate lref Aref newly and try
Preventing negative scalar (UDS) values?? | Matthew Brannock | FLUENT | 5 | September 1, 2020 12:32 |
Negative Drag Values for only some surfaces?? Please help | Jordan1997 | Main CFD Forum | 0 | May 2, 2020 06:39 |
Cannot achieve negative wall shear stress values in CFD Post (ANSYS) | SAtkins | CFX | 3 | August 3, 2016 14:27 |
Negative values for minimum alphas | Taataa | OpenFOAM Running, Solving & CFD | 0 | June 28, 2016 04:04 |
Mass flow rate boundary condition with negative values | ashtonJ | CFX | 3 | November 26, 2014 05:21 |
