How to specify continuous phase (water) diameter in multiphaseEulerFoam or twophasee
Old   May 17, 2023, 14:14
Default How to specify continuous phase (water) diameter in multiphaseEulerFoam or twophasee
Vivekananda
sinhavivekananda318 is on a distinguished road
Hi all,
Currently I am working on bubble column simulation in 2 D. I am using water and air as continuous and dispersed phases. I am a bit confused as I see the transport properties or phase properties file that the water diameter needs to be given. I understand that in eulerian approach diameter of the two phases has to be given , but as water is continuous and it never forms bubble in the practical experiment, so what value should I give in water diameter.
Should I keep it large like say, around 1 meter so that it becomes the continuous phase?
If you can throw some lights it will be very helpful.
Regards
sinhavivekananda318 is offline   Reply With Quote
Old   May 22, 2023, 14:38
Humberto
humber11 is on a distinguished road
That's correct, depending on the type defined in the blending, however if it is defined as none the continuous phase can be considered as 1. An example is the fluidizedbed tutorial. The openfoam in the bubble column case is linear type in blending, so the phases are not fully continuous or dispersed, so the particle diameter has to be specified.
I believe that the diameter to be specified is the diameter of the water particle. Which influences the interphase term of the momentum equation.
humber11 is offline   Reply With Quote
multiphaseeulerfoam, openfoam, twophaseeulerfoam
multiphaseEulerFoam mass transfer / phase transfer geth03 OpenFOAM Running, Solving & CFD 0 January 16, 2023 10:40
Two-phase flow _Problem with phase diameter divergence esma Fluent Multiphase 1 January 8, 2020 15:51
For a single phase flow, is there any way to check water surface level? Tanjina FLUENT 0 February 23, 2014 23:56
Two continuous phase and One dispersed phase Michael CFX 2 January 14, 2010 16:19
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
