May 11, 2023, 02:20 |
how to sample the p_rgh in openfoam v2206
yuwei lin
Rep Power: 3 |
hi! Im new to openfoam. So I was wondering how can I sample p_rgh as a file and can write like timestep in different file rather than all data in a text file.
for example I write a sampleDict to postprocess sample and the p_rgh file will go into the file postprocess and it can write as a independent file like 0.2 0.4 0.6 0.8 1.0 and every p_rgh file will go into the 0.2 0.4 0.6 ....file. cause I need the data become the file that can put into the wssi upfoam to run. sorry about the stupid question. can anyone help? Thanks!! and by the way, the data I want to sample is patch bottom. how can I sample the bottom data p_rgh?? |
May 11, 2023, 09:12 |
M
Rep Power: 12 |
I have a hard time following your "p_rgh goes into that" etc. text, but I think you want certain values put out over time (iteration) of your simulation. In OpenFOAM you can use the surfaceFieldsValue (patches, faceZones, ...) or volFieldValue (cellSet, cellZone, region) function objects to get this output. The documentation is pretty straight-forward on this: https://www.openfoam.com/documentati...ieldValue.html You can just add this to your controlDict as shown in the linked tutorial https://develop.openfoam.com/Develop...em/controlDict and the appropriate files will be written into the postProcess folder created at runtime. Hope this answers your question. |
September 8, 2023, 05:38 |
yuwei lin
Rep Power: 3 |
sorry for reply so late.
I've solve the problem. Thank you for the answer ! |
sample data, sampledict, wave2foam |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 06:54 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
interpolate 2-D sample planes in openfoam | saeedi | OpenFOAM Post-Processing | 0 | August 11, 2015 16:26 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
