Error in fvSchemes
Old   May 10, 2023, 12:20
Default Error in fvSchemes
TGS
TGS
TGS is on a distinguished road
I have a script for fvSchemes file and the fvSchemes and fvsolutions files have defined all the solvers.
This is my fvSchemes file.
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system/fin";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
laplacianSchemes
default none;
laplacian(alpha,e) Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
and this is my fvsolution file.
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
"e.*"
solver GAMG;
smoother symGaussSeidel;
tolerance 1e-6;
relTol 0.1;
// eFinal
// $e;
// tolerance 1e-06;
// relTol 0;
"alpha.*"
solver GAMG;
tolerance 1e-6;
relTol 0.1;
PIMPLE
nNonOrthogonalCorrectors 0;
relaxationFactors
equations
e 0.7;
alpha 0.7;
However, when I run my program using chtMultiRegionFoam solver, always there is an error and the error can be described as follows.
Solving for solid region fin
--> FOAM FATAL IO ERROR:
keyword laplacian(alphae,e) is undefined in dictionary "/home/thamasha/OpenFOAM/thamasha-10/run/tutorials/incompressible/icoFoam/engine/system/fin/fvSchemes/laplacianSchemes"
file: /home/thamasha/OpenFOAM/thamasha-10/run/tutorials/incompressible/icoFoam/engine/system/fin/fvSchemes/laplacianSchemes from line 35 to line 36.
From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
in file db/dictionary/dictionary.C at line 831.
FOAM exiting
I tried to change the key word alpha to alphae too. however, when I did like that way the terminal crashed. I checked all my boundary conditions in both fin and air too. But still struggling with the error. Therefore, could you please help me to solve this.Is that the error with memory?
TGS is offline   Reply With Quote
chtmultiregionfoam, laplacian, openfoam
fvschemes for laminar particles of fluidisedBed gryphaea1635 OpenFOAM Pre-Processing 1 April 26, 2020 17:10
using fvc::interpolate without fvSchemes / manually prescribe interpolation schemes linch OpenFOAM Programming & Development 5 March 20, 2018 06:49
Automatically change fvSchemes after a certain number of iterations jgross OpenFOAM Running, Solving & CFD 2 February 16, 2018 13:16
First order in fvSchemes does not seem to work gerritgroot OpenFOAM Running, Solving & CFD 0 September 30, 2015 21:06
Unrealistic values in cells at edge (high pressure & velocity) - fvSchemes?! matzbanni OpenFOAM Running, Solving & CFD 8 August 24, 2015 17:46
