May 9, 2023, 11:37 |
uniformFixedValue Boundary condition
Rep Power: 4 |
Hi all
I am using OpenFOAMv10, and currently working on a case such that I need to have the velocity field for a patch called droplet (Boundary condition in 0th folder) used within another dimensionless field called alpha as a condition for the same patch droplet. For that I am using uniformFixedValue type coded. (I am trying to use it as a groovyBC) As I am not that good with coding it results in error that U is an unknown identity. I am attaching the code for that patch droplet of alpha field as below: droplet { type uniformFixedValue; uniformValue coded; name drop; codeInclude #{ #include "mathematicalConstants.H" #}; code #{ const volScalarField& U = this->db().lookupObject<volScalarField>("U"); return scalar(mag(U) > 1e-9) ? 1.0 : 0.0); // U as velocity from the boundary condition file 'U' #}; } Thanking in advance. |
May 9, 2023, 14:49 |
Mark Olesen
Rep Power: 40 |
If you have the option to use OpenFOAM-1912 or later, you have expressions (many ideas similar to swak4foam) - you can simply specify the uniformValue type as "expression" and go from there without any additional compilation.
If you do decide to stick with coded, remember that you are trying to write a boundary condition. This means that you need to access the corresponding boundary values of your velocity field (not the entire volume field). The velocity field is of course also a volVectorField not a volScalarFIeld either. After you get at the boundary field part of "U", remember that you need to return a field of values, not just a single scalar. |
May 10, 2023, 17:38 |
Rep Power: 4 |
Hi olesen
Thanks for your quick reply and correcting out my mistake with the vector part. Though even if I do that I am still unable to access the velocity from Velocity boundary file for the droplet patch. It states an error that 'U' was not declared in the scope. How do I get access/read to the velocity field for the patch droplet in the alpha boundary file? Thanks in advance. (Unfortunately I am bound to use only OpenFOAMv10 for this!) |
groovybc, openfoam 10, uniformfixedvalue |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
uniformFixedValue boundary condition | meth | Main CFD Forum | 0 | November 5, 2015 00:16 |
Accessing multiple boundary patches from a custom boundary condition file | ripudaman | OpenFOAM Programming & Development | 0 | October 22, 2014 19:34 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
