An error occurred while attempting to couple OpenFoam with a machine learning model
Old   May 9, 2023, 11:17
Default An error occurred while attempting to couple OpenFoam with a machine learning model
BAI
Rockbeth is on a distinguished road
Hello everyone.
I attempted to update the source item location in the flame table and replaced it with neural network inference. The compilation was successful, but the following error occurred while updating the item. I don't know where the problem occurred. It should have been an error reported when establishing the Tensor.
Here are the error content and interface content
Rockbeth is offline   Reply With Quote
Old   May 17, 2023, 05:11
Josh Williams
joshwilliams is on a distinguished road
Segmentation error means that you are trying to access memory that has not been allocated. This is perhaps something like you are trying to access a pointer that has not been assigned, or an index in a list that does not exist.
In your figure 3, in line 59 the loop looks weird. Why use i<1? Where is inputs_ defined? Seems to be an error with that. Maybe add some print checks or use a debugger (Build OPENFOAM from Source and Debug with VisualCode).
joshwilliams is offline   Reply With Quote
machine learning, mlp, openfoam5.x
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
OpenFoam model compilation error 351Cleveland OpenFOAM 1 January 24, 2011 06:43
