reconstructParMesh getting error. it's urgent
Old   April 18, 2023, 10:24
Default reconstructParMesh getting error. it's urgent
Sanket
Sanketar is on a distinguished road
Dear all,
Whenever I used "reconstructParMesh -latestTime" command, after using "foamJob -parallel -screen simpleFoam" coomand, I encountered the below error.
ERROR--> FOAM FATAL ERROR:
Your time was specified as 153 but there is no polyMesh/points in that time. (there is a points file in "3") Please rerun with the correct time specified (through the -constant, -time or -latestTime (at*your*option).
If anyone having any suggestion please reply asap it urgent.🙏
File Type: jpg WhatsApp Image 2023-04-11 at 13.59.09.jpg (115.0 KB, 26 views)
Sanketar is offline   Reply With Quote
Old   April 18, 2023, 11:43
Yann
Yann will become famous soon enoughYann will become famous soon enough
Your mesh is constant, there is no mesh to reconstruct in your latest time.
Just use reconstructPar to reconstruct your fields.
Yann
Yann is offline   Reply With Quote
Old   April 30, 2023, 13:42
Post add option -allRegions
Wassim Abdel Nour
wa$$im is on a distinguished road
It could also be that you have multiple regions in your time folder.
If that is the case, add the option -allRegions to your reconstruction command.
wa$$im is offline   Reply With Quote
openfoam, parafoam, reconstructparmesh
Urgent problem! Appreciate all you help!! 3D Centrifugal Pump set up problems! RR2 FLUENT 5 April 13, 2012 09:17
urgent help needed (rhie-chow interpolation problem) Ardalan Main CFD Forum 2 March 18, 2011 16:22
Jet flow problem.. PLZ help URGENT!! Vinayak CFX 1 April 3, 2008 19:02
URGENT UDF's erosion_macro problem alex FLUENT 7 October 18, 2005 19:18
transient compressible flow problem (urgent plz) jehanzeb FLUENT 5 August 3, 2004 09:04
