Error while importing ChemKin files using "chemkinToFoam" |
Keshav verma
Rep Power: 0 ![]() |
Hey all,
I am using the chemkinToFoam command for converting he chemkin files for the methane combustion to openFoam compatible files but I got an error while using this command. k__v_e_r_m_a@Keshav-Latitude-E7240:~/Desktop/CH4MECHANISIM$ chemkinToFoam CRECK_2003_C1_C3_HT_KINETICS.CKI CRECK_2003_C1_C3_HT_THERM.CKT CRECK_2003_C1_C3_HT_TRANS.TRC Reactions.c Themo.c /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 10-c4cf895ad8fa Exec : chemkinToFoam CRECK_2003_C1_C3_HT_KINETICS.CKI CRECK_2003_C1_C3_HT_THERM.CKT CRECK_2003_C1_C3_HT_TRANS.TRC Reactions.c Themo.c Date : Apr 08 2023 Time : 12:49:25 Host : "Keshav-Latitude-E7240" PID : 6756 I/O : uncollated Case : /home/k__v_e_r_m_a/Desktop/CH4MECHANISIM nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // --> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword '!VERSION:' on line 1 and ending at line 1046" file: CRECK_2003_C1_C3_HT_TRANS.TRC at line 1046. From function void Foam: ![]() in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 168. FOAM exiting Could you please check out this issue as soon as possible. I am new to openfoam and chemkin a little help will be beneficial I am attaching my chemkin files below |
importing cas and data files from Fluent | azi | Tecplot | 5 | March 3, 2020 13:56 |
Trouble importing airfoil coordinates into Pointwise without using iges files | ColourMeRed | Pointwise & Gridgen | 2 | February 6, 2020 18:59 |
problem in importing fluent case nad data files to tecplot | ganeshranakoti | Tecplot | 1 | March 5, 2013 16:59 |
Importing nodes and elements through text files | rhythm_saini | ANSYS | 0 | February 14, 2012 06:12 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
