FOAM FATAL IO ERROR: Bad token - could not get scalar value file: 0/alpha.water
Old   April 3, 2023, 15:42
Default FOAM FATAL IO ERROR: Bad token - could not get scalar value file: 0/alpha.water
Shuvashish Roy
sroy is on a distinguished road
I am an absolute begineer in OF. I am trying to run a simulation of simple intake struture with culvert. However, when I run the following command:
mpiexec -n 20 setFields |tee setfields.out
OF gives me followig errors:
--> FOAM FATAL IO ERROR: (openfoam-
2206
(openfoam-
(openfoam-
2206
(openfoam-
2206
2206
file:
file:
0/alpha.water
0/alpha.water
 at line
 at line
1616910
1675675
    From
    From
Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&)
Though it writes a alpha.water file and runs
mpiexec -n 20 interFoam -parallel |tee interfoam.out
I am not sure what is causing the error in setFields and alpha.water. Please let me know if I should upload the case files. Thanks.
sroy is offline   Reply With Quote
Old   April 5, 2023, 13:47
Default SetFields is serial only
ryanc6 is on a distinguished road
Roy,
The setFields utility cannot be run on multiple processors. If you run on a single processor this should work fine.
ryanc6 is offline   Reply With Quote
Old   April 5, 2023, 13:56
Shuvashish Roy
Ryan, I can't thank you enough for your help with my openFOAM problems.
alpha.water, fatal io error, setfields
[openSmoke] LaminarSMOKE compilation error mdhfiz OpenFOAM Community Contributions 8 July 2, 2024 11:32
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
